Hoe to transplant trees?
   / Hoe to transplant trees? #1
jsec
Murrysville, PA
Kubota B21
Anyone have experience or ideas on using the backhoe (mine's a Kubota B21) to dig out trees for transplanting? Developers are about to level the property adjacent to mine and I can take whatever trees I want. There are hemlocks and spruce in the 8-10 foot range and some dogwoods with about 3" to 4" trunks.
   / Hoe to transplant trees? #2
The height of a tree will somewhat limit your ability to use the hoe alone but I helped a friend relocate a tree by using the hoe to dig a trench on all four sides with a ramp down one side. Then I drove the tractor down the ramp using the FEL to lift the tree. Work slick but leaves a much bigger hole to deal with /forums/images/graemlins/smile.gif
   / Hoe to transplant trees? #3
Did some pines and they mostly lived.
Dig your hole first, then go get as much rootball and dirt in the bucket as you can along with the tree and put the whole mess in the new hole. Dont transfer the tree in and out of the hoe bucket, in when you dig it, out when you plant it.
   / Hoe to transplant trees? #4
We transplanted about 15 similarly sized spruce trees in my yard a month or 2 ago.
Backhoe around all 4 sides about 2' out.
I then slid the FEL bucket under the the tree, ran a strap around the trunk of the tree (back to the bucked) and did a combination of lifting and dragging to get it out.
The bugger was establishing and planting into the target hole. You'll need to pull the tree out, eye-up how big of a hole you need, dig new hole and plant it.
So far... All seem to be doing well.
You're not too far away from me (about 45 miles). Have you checked with a local nursery or tree farm? The one down the road was going to bring a skidsteer with one of those cone shaped tree diggers (sorry, forgot what they're called) and do it for me for $15/tree.
EDIT - PS. Varmintmist and I wrote the same thing at the same time. Sorry for the duplicate respone.
   / Hoe to transplant trees? #5
<font color="blue"> The one down the road was going to bring a skidsteer with one of those cone shaped tree diggers (sorry, forgot what they're called) and do it for me for $15/tree </font>
That's called a tree spade and that's one heck of a deal!
   / Hoe to transplant trees? #6
Thanks. Couldn't recall what it was called.
I guess it didn't hurt to give him a couple "refreshments" before asking for a quote. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Actually, I think it was because he's good friends with one of my neighbors. /forums/images/graemlins/wink.gif
   / Hoe to transplant trees? #7
Do bewere of how tippy your machine gets carrying a tree with tree limbs up in the air like that. A breeze can have a significant affect on your balance. The roots and dirt should keep you grounded, but sudden settling and a little shift and you could be on your side with a tall tree.
Cliff
   / Hoe to transplant trees? #8
OkieG initiated a good discussion on this topic a while back. Try a search - I think his attempt failed, but if I recall correctly his tree was 40'+. I've successfully transplanted many trees up to 4" dia using a technique I outlined in his thread.
   / Hoe to transplant trees? #9
Did someone say trees carried up high can make tractors and backhoes tip over? See the attached for a real life example. A major brain cramp of my part. It worked out OK, but took a lot of work. I jacked up the spade/root ball using a 2 ton and 3 ton jack to the point where the bobcat would start, then lowered the spade and finished the job. Never again!
   / Hoe to transplant trees? #10
I saw dedicated hoe on agfair a week ago.
Maybe you're looking for this one?
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
John Deere XUV560E 4x4 Utility Cart (A50322)
John Deere XUV560E...
2012 International 4300 Reefer Truck (A52748)
2012 International...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
