Snow Equipment Owning/Operating HLA1000
   / HLA1000 #1
delgra
Bronze Member
Combermere Ont
Kioti NX4510hst
Just took delivery of an HLA100072 hydraulic plow. Made in Ontario!! Installed it on my Kioti CK35hst this pm and plowed. I had been using the FEL to plow and thought this would be an approvement. Its slick (8 Way) and faster than the FEL, but harder to do those tight spots where you have to pile rather than push. Its a perfect match for the tractor and there is no want for more power. The QA feature is quite nice, but having to run the long lines to the rear for the hydraulics is a pain. I think I will add disconnects for those lines at the front rather than reroute them to the back every time I take the plow off. Any words of plowing wisdom would be appreciated. Bob
   / HLA1000 #2
About your snow blade,
You should spray or coat the blade with fluid film to aid plowing and avoiding having snow stick to the blade.
About the hydraullics-what your saying is the loader remotes are sized differently and you have to use the rear remotes for the plow?
   / HLA1000
The option of using the FEL supplies never came up. I'am not too much of a mechanic so I usually go along with the pros. Its not too hard to put disconnects at the front, but I may sell the unit as I don't see a huge improvement over the FEL but time, and thats what I got, honey, time. Besides I wanna a chipper/shredder.
   / HLA1000
I forgot the spray. WD40 or what? A good suggestion.
   / HLA1000 #5
I have a QA plow for the front of my L3700. Once it is on and the angle is set, I hook up to the curl in/out ports and that's it. I have left right up and down. A 3rd function would be nice but not really needed for the plow
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2008 ELGIN SWEEPER (A52472)
2008 ELGIN SWEEPER...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2012 INTERNATIONAL PROSTAR (A52472)
2012 INTERNATIONAL...
