Hitch ratings.
/ Hitch ratings. #1
plowking
Nottingham, N.H.
2009 MF 1531 TLB
My hitch frame on pickup is a Class III, but the receivers I have for 2 inch ball have a lower rating than the hitch. Do they make a receiver with Class III rating and would ball have to be 2 5/16 inches, even though my trailer is a 2 inch coupler on tongue of trailer. plowking
/ Hitch ratings. #2
You can find drawbars and hitch balls with many different ratings. I can't remember where I bought all my stuff, but it all came web ordered. I started with a class IV hitch (should have went class V) because I had heard of factory Dodge hitches breaking. It is rated at 8k with 800# tw. I bought a solid steel adjustable drop bar rated at 10k and my 2inch ball is rated at 8k. I don't have a weight distribution setup on my truck at this time. I think my hitch would be rated at 10k if I did. Search for manufacturers like draw tight, putman or putnam or hidden hitch. I think I bought from etrailerhitch.com and I also bought from truckperformance.com when they were running a free shipping sale. Higher rated drawbars will use a ball with a bigger shank. I think mine is 1 1/4 inches. They also come in 1 inch and 3/4 inch. JC
/ Hitch ratings. #3
Everything has a stamped rating on it from the frame mounted receiver on back. It is OK to have a higher rated piece in the chain somewhere, just find the lowest rated link and use that rating for the whole system.
You won't find a 2" ball or even a 2-5/16" ball rated for 10k at walmart.
/ Hitch ratings. #5
I am also concerned about the 2'' trailer ball rated at only 6000 lbs.I'm pulling over 6.5k so that would be the weakest link?.Does anyone have a 2'' ball rated at 8k or more with a 1'' shank?. Or do I need to get a new 2'' insert drilled 1 1/4 for a heavier rated 2'' ball.
Or should I not be concerned about my little 5k 2'' ball.Anyone ever have a ball snap off?.
/ Hitch ratings. #7
Draw.tite makes very good hitches , and all the parts to go with them , I use class 4 , and buy them at u-haul
/ Hitch ratings. #8
I use a class V hitch on my Dodge and my 2 5/16" ball is rated for 10,000 lbs. I would have to look at my 2" ball to see what that says but that one is for my horse trailer, which with 2 horses comes in about 5000lbs. As for the ball mounts, they can be hard to find locally (at least around here) with a rating of more than 6000lbs so you may have to look online for that.
Any trailer dealer should be able to change out your trailer to take a different kind of ball hookup if that is the way you need to go to be able to tow it properly. I have actually been considering going with a pintle hitch for extra safety.
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2013 Ford Taurus Sedan (A64557)
2013 Ford Taurus...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
Adams Tilt Trailer (A63688)
Adams Tilt Trailer...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
