3-Point Hitch Hitch quit working
   / Hitch quit working #1
WRB
TC40A
I have a TC40A, fluid is full, 3 point hitch just quit working, won't lift. Any good ideas and/or where can I get a diagram and/or shop manual on what is going on? Front end loader still works fine.
   / Hitch quit working #2
Does the TC40A have draft control?
larry
   / Hitch quit working #3
Okay, there are two things to check. 1st, do you have hydraulic remotes on the rear? If so, make sure the handles are centered. If they stick and don't return to center, your 3PH will not work.
Most likely you have an out-of-place (loose) power beyond plug inside your FEL joystick valve. Look at the photo and illustration below. You need to remove he cowling around your joystick and remove the circled cover. There is a small plug beneath that cover that loosens and allows fluid to bypass the rest of the system and go directly to the reservoir.
THANK YOU very much. The allen plug had come completely unscrewed and out. Put it back in, tightened it some but not too much because I did not want to strip anything out in the valve, and it works like a champ.
Thanks again,
Wayne
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2020 Husqvarna YTH22V46 46in Riding Mower (A56859)
2020 Husqvarna...
2020 DRAGON ESP...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
