Loader Hitch not raising when the loader is detached.
   / Hitch not raising when the loader is detached. #1
bxkubota
Latrobe, PA
BX25
Have friend with a bx2200 and a Woods brand loader. When he takes the loader off the rear hitch won't raise or lower. With the loader attached it works normal. Any ideas or pics of how the hoses should be connected would be appreciated. The loader valve comes off with the loader.
   / Hitch not raising when the loader is detached. #2
If the loader valve has three hoses(not counting the four to the loader cylinders), I suspect when the valve is uncoupled, the pressure line is being connected to the sump return instead of the lift supply. Find the supply line from the lift, follow it forward and see if you have an oil supply attached.
   / Hitch not raising when the loader is detached. #3
I think Harry is right. I looked at the parts for the loader and the loader came with 3 or 4 different valves. One of them it looks like you have to hook the pressure line to the PB hose. I would think the Q coupler should have the right couples so you can't get them wrong. Look them over real good.
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
200lb Anvil (A55853)
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A57193)
UNUSED LANDHERO...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
