Hitch N ditch
/ Hitch N ditch #1
Nuru
Elite Member
Hitch-N-Ditch
Tried out this attachment on my tractor. Works pretty well as i was able to get 250 of direct burial line done in about two houes. A few observations:
This device was designed to work on a receiver hitch mounted on a truck. I was trying to use it on my tractor , first on my 3PT hitch mounted trailer hitch attachment - broke that right away:eek: There went the 80 bucks on that:mad:. Then I went to a drawbar mounted receiver hitch. That worked, but silly me, I tried to turn with it - not a good idea!:eek:.
These device is designed to be used with a solid, very stiff receiver hitch. My drawbar mounting is not as stiff as you really need, as I was trying to do this in a hurry and just pinned the receiver hitch instead of bolting or welding it to the drawbar.
Since i want the wire a bit deeper than I got it (my property is a bit slopey). I will get the receiver hitch either welded on my Drawbar or bolted down solid, and then re-run the cable. i might even put it inside conduit.
Overall impressions good tool, use of multiple pilot holes to accommodate turns is a good idea. The tool is sturdy, and it survived my experimentations:rolleyes:, pretty well.
/ Hitch N ditch
OBTW, i also used it in the roughest conditions, root structures, rocks, and slopes. If used in optimum conditions and been more experienced with the tool, the job would have taken approximately 20 minutes or less
/ Hitch N ditch
Next task - sprinkler system!
/ Hitch N ditch #4
A subsoiler for a truck. Interesting. I am not sure how that would effect the 500lb tongue wieght capacity. Seems like it could really tug on a truck given the wrong soil conditions or very big root/rock. Neat idea though. Glad it worked out for you.
/ Hitch N ditch #5
I can see how would work on tractor, but I don't think that would never work on a truck trying to pull it through Ozark soil!
/ Hitch N ditch #6
Nuru said:
Hitch-N-Ditch
Read the disclaimer. You'll probably twist this thing into a cork screw if you try it in soil with rocks and/or roots. It's not really designed for 3pt hitch use. The mfg says it's for 4WD trucks and for work in light, prepared soil.
I dug more that 1000 feet of 4" wide trench (18" and 24" deep) using a Ditch Witch 1330 to get the electric power, water and gas lines into my new house. I killed that 11 hp Honda engine on the 1330 a lot when hitting roots and rocks.
/ Hitch N ditch
Well it worked okay ibn my soil and now i really know how to use it in my conditions, so it seems okay. But for the sprinklters, i may have to go to something heavier like my Subsoiler, which has not failed me yet!
/ Hitch N ditch
It does seem a bit light, and it intened to be used on fill dirt or soil without too many roots. It does have a sharpe edge so it will cut through roots, and does move rocks. I think by taking out any slop in the connection points, will make it much stronger.
/ Hitch N ditch
Well it is not quite a real subsoiler, as it is not very strong and does not like turns, especially ones like the ones i pulled on it last weekend. But more gradual turns could be tolerated.
/ Hitch N ditch #10
Any pics? Sounds interesting.
2014 Jeep Grand Cherokee SUV (A66738)
2014 Jeep Grand...
1988 Ford 7610 Series II 4WD 97HP Agricultural Tractor (A66734)
1988 Ford 7610...
Skidded fuel cell (A67714)
Skidded fuel cell...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2018 Ram 1500 4x4...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
Unused 2024 Land Pride PF1242 42. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
