Hitch for Scotts lawn tractor
   / Hitch for Scotts lawn tractor #1
SCOOBY14B
Cleveland, Georgia
Kubota BX2660 Ansung B2504 FE loader and Kubota MMM
I have a Scotts 17.542 lawn tractor (17.5hp). The piddly hitch hole is bent. I am looking for ideas on making a better/ stouter hitch for the rear that will be very sturdy and a bit higher. Or if anyone knows of a place that sells them.
Thanks
   / Hitch for Scotts lawn tractor #2
I believe that John Deere makes the Scotts lawn tractor. Maybe check with a JD dealer and see what they have to say. G
   / Hitch for Scotts lawn tractor #3
I would try to straighten what Scott's has already given you and then weld a support with a hole in it just underneath the original bracket.
   / Hitch for Scotts lawn tractor #4
Buy the sleeve hitch accessory, this allows you to use ground engaging implements, as well as, provide a better/stronger towing point. Check out Scott's
   / Hitch for Scotts lawn tractor #5
<font color="blue"> Buy the sleeve hitch accessory, this allows you to use ground engaging implements </font>
That sleeve hitch is exclusively for the 2554. That was the only tractor in the line-up with a transmission rated for ground engaging implements.
Don
   / Hitch for Scotts lawn tractor #6
TSC has what looks like a universal hitch. Good point on the transmission, you don't want t over-work it.
2018 John Deere 460E Articulated Dump Truck (A53473)
2018 John Deere...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
CRESCENT  MANIFOLD TRAILER (A53843)
CRESCENT MANIFOLD...
2005 CHEVROLET SILVERADO (A53843)
2005 CHEVROLET...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
