Hitch for Scotts lawn tractor
   / Hitch for Scotts lawn tractor #1
SCOOBY14B
Cleveland, Georgia
Kubota BX2660 Ansung B2504 FE loader and Kubota MMM
I have a Scotts 17.542 lawn tractor (17.5hp). The piddly hitch hole is bent. I am looking for ideas on making a better/ stouter hitch for the rear that will be very sturdy and a bit higher. Or if anyone knows of a place that sells them.
   / Hitch for Scotts lawn tractor #2
I believe that John Deere makes the Scotts lawn tractor. Maybe check with a JD dealer and see what they have to say. G
   / Hitch for Scotts lawn tractor #3
I would try to straighten what Scott's has already given you and then weld a support with a hole in it just underneath the original bracket.
   / Hitch for Scotts lawn tractor #4
Buy the sleeve hitch accessory, this allows you to use ground engaging implements, as well as, provide a better/stronger towing point. Check out Scott's
   / Hitch for Scotts lawn tractor #5
<font color="blue"> Buy the sleeve hitch accessory, this allows you to use ground engaging implements </font>
That sleeve hitch is exclusively for the 2554. That was the only tractor in the line-up with a transmission rated for ground engaging implements.
Don
   / Hitch for Scotts lawn tractor #6
TSC has what looks like a universal hitch. Good point on the transmission, you don't want t over-work it.
1275 (A50490)
1275 (A50490)
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A51694)
2008 Nautica...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2009 Yamaha Golf Cart (A52377)
2009 Yamaha Golf...
2015 MACK CHU (PINNACLE) TRI AXLE(INOPERABLE) (A53843)
2015 MACK CHU...
FORD F750 XL SUPER DUTY TRUCK (A51406)
FORD F750 XL SUPER...
