Hitch failure on a Diamond C FMAX 212
   / Hitch failure on a Diamond C FMAX 212 #1
nisaacs
Platinum Member
Snowflake, Arizona
970 John Deere 4x2, 970 John Deere 4x4, 4320 John Deere, 995 Case/IH
Hitch failure on a Diamond C FMAX 212, GVW 25.900k I think. I think the hitch is rated 30k, based on their web site. You can see it has been broken for a long time with the wear marks. Crazy it broke in the first place.
   / Hitch failure on a Diamond C FMAX 212 #3
That is in an interesting break. Your photo shows the telescoping part that broke off in the inside.
   / Hitch failure on a Diamond C FMAX 212 #4
It broke right where the set-screw tightened into it....interesting. It looks like the screw focused the stress at that point.
Armchair quarterbacking, I agree:) If they are too tight, they can distort the tube. I think the recommendation is about 90 lbs tq.
However, there seem to be several of these break, from what I am hearing. China steel maybe?
   / Hitch failure on a Diamond C FMAX 212 #6
I think if a set screw made that fail they used the wrong thickness of steel.
   / Hitch failure on a Diamond C FMAX 212 #7
When i ordered my diamond c 212, I purposely upgraded to the square coupler tube. No issues and I run heavy regularly.
Looking at it from an engineering point of view, if the inner tube failed first, the outer tube would absolutely fail in rapid succession. DC doesn't build the inner tube (bulldog?) and the outer tube certainly isn't designed to operate alone. Crappy regardless and I hope your insurance covers the new trailer!
Looking at it from an engineering point of view, if the inner tube failed first, the outer tube would absolutely fail in rapid succession. DC doesn't build the inner tube (bulldog?) and the outer tube certainly isn't designed to operate alone. Crappy regardless and I hope your insurance covers the new trailer!View attachment 819839
Nice trailer, and I really like those log bunks.
   / Hitch failure on a Diamond C FMAX 212 #9
I also ordered the square tube hitch and also the 3” ball. I try to overbuild everything I possibly can. Costs more, but catastrophic failures are (hopefully) not on my bucket list.
Going off memory here but I think your trailer is rated 38k gvw. So, 40k square hitch and 3" ball would be standard equipment. Even more so, with a deck on the neck. I have not seen a round hitch go over 30k gvw. However, they do make lighter duty square hitches for lighter duty gvw trailers.
2013 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2013 POLAR TANK...
2012 Ford Econoline Cargo Van (A56858)
2012 Ford...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
John Deere 1025R (A53317)
John Deere 1025R...
2020 CATERPILLAR 323 EXCAVATOR (A52709)
2020 CATERPILLAR...
