hitch extension
/ hitch extension #1
jam2004
central NJ
Kubota BX 2230
When pulling my manure spreader, the control levers often make serious contact with the 2230's lift arms (in up or down positions). Are they any pre-fab extensions out there that will give me more space between the hole in the back of the tractor and the hole in the tongue of the spreader? It's particularly bad when the spreader is on higher ground than the tractor.
/ hitch extension #4
Some draw bars have multiple holes where they pin to the tractor, does the BX?
/ hitch extension #5
Jam,
I had the same problem with my sprayer. What I did was buy a draw bar. It connects to the 3 point.
See this e-bay picture
web page for what they look like. Just make sure the holes for your spreader will fit the bar, it is about 3/4" thick. The draw bar was about $15 at the local farm store dealer.
/ hitch extension #6
Here's how I solved the problem of the fixed drawbar on my BX. Just get a 2" hitch that has the reach and lift that you need. I unbolted the original drawbar plate and used it as a template to make the holes for the new one. Disregard the marking that I added to the pic for someone else.
/ hitch extension
</font><font color="blue" class="small">( Jam,
web page for what they look like. Just make sure the holes for your spreader will fit the bar, it is about 3/4" thick. The draw bar was about $15 at the local farm store dealer. )</font>
Tom,
I went to a place in Hightstown today and saw the draw bar you've referred to. Does that attach to the lift arms? Do you have to keep the deck in the low position to connect the draw bar? I like to keep the deck on in the up position. I think that means the lift arms are also in the up position.
jam
/ hitch extension
</font><font color="blue" class="small">( Here's how I solved the problem of the fixed drawbar on my BX. Just get a 2" hitch that has the reach and lift that you need. I unbolted the original drawbar plate and used it as a template to make the holes for the new one. Disregard the marking that I added to the pic for someone else. )</font>
Milk,
Do you use the bolt from the the original drawbar plate to reattach the 2" hitch? Do you have any problems with the rear implement being more unstable than normal due to the extension?
jam
/ hitch extension #9
You can see how mine is attached over the original hitch.
/ hitch extension #10
Jam,
What I do is lock the MMM in the top position. Then the draw bar can be at what ever height you want. The ends of the bar go through the balls on each side of the hitch. A pin holds the draw bar to the hitch. The draw bar will rotate. It is not a problem with my spray because the connection on the sprayer is a "C" with a pin in the center. I connect the sprayer to the draw bar, add the pin and away I go. If you need a picture let me know.
In Kevin picture above the red bar is the draw bar and the orange part prevents the draw bar from turning. Not sure where you can get that part, you do see them on e-bay.
here is an example web page
Here is cheaper way to prevent the bar from turing.
web page
/ hitch extension
Tom,
Thanks for breaking it down for me. I'm going to check out the 'Bota's rear end tomorrow morning and see how it all will play out with the front of the spreader. That first ebay item is a tad costly. The red thing seems to be essential in keeping the bar from rotating.
jam
web page )</font>
/ hitch extension
</font><font color="blue" class="small">( You can see how mine is attached over the original hitch. )</font>
Kevin,
Is that a metal plate under the hitch bar? I like your solution. It looks practical and inexpensive.
jam
/ hitch extension #13
If you use anything like a trailer attached to your 3-point it can dump as the 3-point moves upward unexpectedly.
Our solution was to weld a receiver tube on a short draw-bar. We can then add any length hitch or draw-bar extension made from common 2 X 2 X 1/4 square tube. We can keep our 3-point weight rack in place and still be pulling our trailer without worry that it will be dumping on its own.
When finished we pull the tube out of the receiver so there is nothing to bump your shin on when walking around the back of the tractor.
/ hitch extension #14
</font><font color="blue" class="small">( In Kevin picture above the red bar is the draw bar and the orange part prevents the draw bar from turning. Not sure where you can get that part )</font>
I made the orange part from scraps in the shop. The bar also holds a lead weight.
/ hitch extension #15
Here's my solution. Draw bar was $15 at Fleet Farm, Upper was scrap from garbage at work. 15 min with the welder, and here you go. /forums/images/graemlins/grin.gif
3pt trailer hitch
/ hitch extension #16
Just remember one thing. When you lengthen your drawbar you must reduce the load accordingly. Look in your manual for the maximum load at the drawbar end and load your spreader cautiously. From my observance, most Kubota's mount their drawbar bracket to the bottom of the transmission casting. Breaking that bracket off could be VERY expensive. /forums/images/graemlins/grin.gif
/ hitch extension #17
Here is a better pic.
/ hitch extension
</font><font color="blue" class="small">( Here is a better pic. )</font>
Kevin,
How is it fixed to your tractor?
jam
/ hitch extension #19
You are looking at the bolt heads which are welded to the extension for ease of mounting or removing. Two original bolts have to be removed and replaced with longer bolts. (these are the two near the transmission).
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2022 EZ-GO ELITE...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2006 International 7600 T/A Flatbed Truck (A64194)
2006 International...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
