Historic winter storm ENZO
   / Historic winter storm ENZO #91
Where I am in California it's rare to get below freezing and when it does it's only a few degrees. At least that's true so far. The plumbing is done with no thought for freezing- pipes left exposed, regular hose bibs instead of freeze proof hydrants or bibs with the valve inside the building.
At my place in Oregon it does get below freezing pretty regularly. Plumbing there is more complex as a result, and probably more like what you're used to. For example I wanted hose bibs on the outside of the unheated garage. The plumber said I can't, they'll freeze. We compromised with an extra valve in the heater apartment above the garage that I can use to shut off water to the bibs, and I'll have to remember to drain them. I'll have to keep the shop heated to keep the pipes there from freezing.
   / Historic winter storm ENZO #92
I would add automatic frost tape on the bib piping. I think that it is human nature to forget, or be out of town, when a sudden cold snap happens.
All the best,
Peter
   / Historic winter storm ENZO #93
We use these, water is shut off in the heated area of the house.
Plumbing must be handled differently there... Here we have multiple days where it is 0f and below... And we don't run water to keep it from freezing.
You are correct. Anything below the surface does not need freezing protection. We usually do something to protect pipes that are above ground.
About once or twice a year, we will get temps down in the 20's when pipes and citrus trees need protection. About once every 10 years or so, we get down into the teens.
On January 22, at 5:53 am, the National Weather Service recorded at temp of 5* F about 15 miles east of me in Lafayette, La. That is the coldest ever recorded. I do remember a temp of 9* in 1989 just before Christmas.
   / Historic winter storm ENZO #96
They are great when the inside end is in a heated space, which might work for some, but isn't likely to work when the inside is in an unheated garage up north.
Speaking from personal experience they also aren't infallible when you get even farther north below -10F or so, as the inner end can get down to below 32F. In one house we had to put on outside styrofoam caps on ours to keep them warm enough to prevent the inside pipe from getting damaged, and another got indoor heat tape.
I prefer to have spigots/faucets like these to have an indoor shutoffs so that they can be completely drained when the outside drops to near or below 32F. That may sound belt and suspenders, but I have experienced these freezing, and the home builder didn't always ensure that inner end is readily accessible.
All the best,
Peter
   / Historic winter storm ENZO #97
All the best,
Peter
If you've got a water line in an unheated garage up here, you've got a bigger issue than just what kind of spigot you have. That line needs to be shut off and drained for the winter. We have an internal heater in the line feeding the upstairs room in our garage. It runs inside the pipe from the second floor down to several feet underground. Even with that, we drain the line for the winter. The last thing I want to deal with if we get a power outage in the winter is draining that line, or wasting generator capacity and fuel keeping it heated.
   / Historic winter storm ENZO #98
In our area, people insulate their homes to keep them cooler in the summer, not to keep them warmer in the winter. Some years it never gets under 32 degrees and when it does it will usually only break pvc pipes and not copper pipes. I have never seen a snow blower or a snow plow and I don't know anyone who wants to get one for an event that only happens every 150 years.
We don't fortify our roofs to handle heavy snow loads but just to hurricane proof them. I would need someone from up north to teach me how to make a snowman. In exchange I will teach them how to prepare for a hurricane. Northerners who come to New Orleans think a Hurricane is something you buy at Pat O'Briens to drink. And we call a snowball a crushed ice treat topped with delicious syrups. A snowman is a fictitious creature like the abominable snowman.
An 8 inch rain occurs at least once yearly but a 1/2 inch snow only comes about every 15 years. I don't know what an overcoat is. What are snowboots? I have been to Alaska between May and September, at least the southern part of Alaska, 5 times but never seen as much snow as we have had this week. Only once when we crossed the continental divide in Colorado have I seen this much snow.
You Yankees can have the blizzards but give me a hurricane anyday.
   / Historic winter storm ENZO #99
Old cabin in snow company with galvanized pipe never an issue.
The newer homes with copper in the area not so trouble free.
Some have added heat tape which works... when the tape is on.
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
2018 Seal Rite SR 700XP Seal Trailer (A52384)
2018 Seal Rite SR...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
