Hinomoto E324 clutch
/ Hinomoto E324 clutch
oh crap....
the release bearing i have is WRONG... unless i was sent the wrong part, it's not the same as on the MF 1030. The part number is NACHI 45TMK-1 that came out of the tractor. I bought whatever is for the MF 1030
the pressure plate i have is WRONG... it doesn't match the one i took out. the center hole is different. I have no clue if the clearances are the same either.
the only thing i can tell that looks right is the clutch disc.
Dammmmmmmmmmmnnnnnnn
this is not where i want to be.
i wonder if the MF1030 pressure plate and release bearing combination works together or not? Arrrrrgghhhhh! terrible.
/ Hinomoto E324 clutch #22
The 324 is NOT a match to any MF. The 1030 is closest to the 2304, a much smaller tractor. You can match the bearings up at a bearing supply dealer and have the clutch and pressure plate rebuilt or have Len Shaeffer order you one from Japan. A 2604 is the biggest tractor that matches a MF.
Eugene
Eugene
I should have contacted him first, but now I'm in a situation where i have about $300 of parts, and probably identified the right one from a guy that has the same parts i need... so probably a swap of some sort will happen. Maybe I'll call Monday to see if he's willing to confirm what I've found. I'd hate to call him, give him prospect of selling me something knowing I already have something in mind. If he helped, I'd keep him in mind for future stuff.
i think this is actually what i need... i got bad information the E324 is the same clutch parts as the MF 1030 from someone recommended from this site. I think it's really the same as the MF1233. Free advice is free advice... it goofed me up, but it was free advice. I sensed something may have been wrong when i saw parts diagrams for the MF1030 and it appeared some of the driveshaft configuration and parts were very different.
1233 MASSEY FERGUSON COMPACT TRACTOR CLUTCH | eBay
this looks like the same clutch, and appears the same measurements.. they say 9" but i think it's really like 8.75.
I took measurements, and that is also a spitting image of what i have.
/ Hinomoto E324 clutch #24
It appears the loader will have to come off. to replace the clutch, the tractor has to literally be split (separated) at the bell housing. Engine half pulled forward, transmission half pulled back.
Was the clutch slipping prior to this happening ( did you notice you required that you needed to use lower and lower gears for it to pull itself for instance)? Does the pedal feel normal when you push down on it? I assume the tractor is in neutral (?), can you rock the tractor back and forth a little and get it to engage a gear? Or if it's in gear rock it and get it out of gear?
Just trying to get a better idea of what was going on leading up to the problem and if it may be something else.
TractorClutchesRUs - Tractor Clutches has served me well for clutches in the past and I believe they can reline your old one if they don't carry a replacement in stock. I'm sure they can supply a pilot and throw out bearing as well ( you may have to take the old ones out and measure them first though.).
The ebay listing of the MF clutch is the same seller I posted about previously. Very nice gentleman and if you purchase a new clutch plate, he will give you $25 for your old one if you send it in. I think it is very likely he will have/or can get the correct pressure plate too.
i just talked with him on the phone about 5 minutes ago. we're working something out. I took a few better photos and contacting him shortly. Although i'm not going to lie to him and tell him i ordered it based on the picture and already told him so, the clutch on the MF 1030 auction is NOT for the 1030, it's for the 1233. It's the wrong photo. I recommended change it.
/ Hinomoto E324 clutch #26
Eugene
I think you're exactly right about the 1030/2304 cross....Bruce laten had told him that the 1030 clutch was the same as the 324's. Heck if I know but I sure wouldn't be suprised if the 1030 had an 8" and the 324 used a 9" and beefier bearings. I think you're right about there not being a close MF cross to the 324 but I will bet there are still enough similar parts and design used in MF 1035/1040/1045 to pay attention to them when trying to figure things out or looking for parts.
He thought i said the E224, he replied today agreeing it was the MF1233. Measurements given to the clutch builder based on the old seem to confirm that.
The release bearing appears to be the same though. The Nachi part is discontinued but i received an A&L although slightly different appearance, critical dimensions appear identical to original.
the one thing i don't take a picture of how it went in/out... The little spring shown goes on boths ides of the release sleeve. There is a little hole on the sleeve in the back of each. one end of the spring (not sure) goes in it, while the other goes to ??? i can't see anywhere obvious.
if i put it like this:
it doesn't say on the fork. It just slips off down... i don't see a hole for the sharp hooked end to go into. Am i missing it?
If i put it like this:
again, things don't make sense.
This is an up close... there is a little hole it does into on the part with the release bearing on it.
/ Hinomoto E324 clutch #29
If you look at the AGCO parts book at the 1035 clutch housing and shaft diagram it looks most similar to your pics and shows the spring ( 2 actually). The 1030 diagram shows 1 but the spring looks most similar to your your spring from the pics you posted. I assume the direction the springs are shown in the diagrams indicates how they sit/ their orientation. Try looking at the diagrams and see if it gives you a clue as to how it fastens.
ironically this was open in the background as you posted... this is for the 1233 though.. i'll check the 1030. Following the 1030 has got me into trouble already once.
Uploaded with ImageShack.us
MF1030
close... but doesn't show really the orientation on how it hooks up on the fork side. I don't see any holes on the fork like the parts book implies. There looks to be a few other parts i don't have too.
/ Hinomoto E324 clutch #32
As Hinomotoman has pointed out the 1030 is a much smaller tractor BUT that doesn't mean that it can't use some of the same parts or similar designs in different areas. I just thought that the clutch plate would be an odd match simply because of the HP and size difference between the two tractors. Be sure to look at both the 1030 and 1035 diagrams and see if either look like the 324's spring set up. If not, start looking at other MF compact models and see if you can find another match that may help.
It kind of looks like the 1045 but the artists rendition of the return springs is questionable:
the fork has little holes in it.... i'm pretty sure i didn't
/ Hinomoto E324 clutch #34
I went back and looked at your pics in "full image" then increased the page size by 400% and it sure looks like there is a small hole in the side of the fork in the second pic. Maybe I'm seeing a piece of crud or something or just being overly hopeful but check it closer because I think there might be.
I left it alone for the night (sleep on it and return later) but i'm pretty sure there isn't a hole on the side of the fork like the MF1233 drawing. The MF1233 drawing shows the holes for the spring on the slide part kind of tangent to the slide vs. perpendicular like mine.
The fork... i didn't see anything on both sides but i'll take a small detailing pick to scrape around. I could have swore there was quite a bit of spring tension to keep the slide resting against the fork too.
not where i want to be right now with this.. :confused:
https://picasaweb.google.com/ken.mayle/HinomotoE324#5610832417235064738
deleted due to messed up refresh...
okay, i finally found the location of the holes on the back of the fork using what equates to a dentist hook:
If i push back the release bearing back, the springs simply fall out. Is this normal by design or did i possibly bend the springs when removing them or ???
should under normal conditions the guide tabs rest on the shift fork, or is the point to have a slight gap and then the clutch slowly engages... maybe this is an adjustment discussed way earlier when i was first diagnosing this?
here is a video i made talking about the above:
YouTube - ‪Hinomoto Clutch Fork Springs Is this right?‬‏
and the original photos:
(see the latest ones)
/ Hinomoto E324 clutch #38
Maybe Hinomotoman or one of the grey market gurus will know and respond but if no one can answer this soon you may try asking in the Massey forum. There's no doubt that This is a design that was used on their tractors so someone there has to know.....may get someone with an attitude about the Hinomoto/MF thing but I'm certain there will be someone willing to help.
/ Hinomoto E324 clutch #39
That looks like the setup on my deutz allis 5220 HST and the same as the MF1020. I saw dad pop the spring off and it was on there tight, I don't remember it being in that position thou.
one could describe it's in there tight other than in the "Push" back direction. it follows the clutch fork in and out and doesn't twist. I'm just thinking that maybe when all the clearances are factored in in normal operation the bearing only has so much movement and won't ever physically be pushed backwards. I really have no idea with the parts i took off it would work any other way? :confused:
F-450 SuperDuty Flat Bed 4WD (A63688)
F-450 SuperDuty...
John Deere 8345R (A64126)
John Deere 8345R...
Bad Boy Rogue (A64127)
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
iDrive TDS-2010H...
