Hinomoto e204
   / Hinomoto e204 #1
az_rooster
can someone tell me how to remove the oil pan from the e204 the drive shaft seems to be in the way and do not know how to pull the drive shaft any idea or help
   / Hinomoto e204 #2
1 Set front of tractor on jack stands.
2 Remove the 3 bolts from the rear driveshaft housing.
3 Remove the 4 bolts from the front carrier bracket.
4 Remove the 2 bolts from the rear carrier bracket.
5 Drop the front axle down and roll forward.;)
Eugene
Formerly buppy69
   / Hinomoto e204 #3
You make it sound easy.
   / Hinomoto e204
got all that done but having a hard time to get the drive shaft an front axle to move
   / Hinomoto e204 #5
The splines on the shaft going into the transmission are probably stuck.May take some force.
Eugene
formerly buppy69
2023 Zimmerman 4000 XL (A53472)
2023 Zimmerman...
48" Pallet Forks  (A52384)
48" Pallet Forks...
RING 2 STARTS HERE @ 9:30 AM (A51247)
RING 2 STARTS HERE...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
TUBELINE TL50LSV LOT IDENTIFIER 107 (A53084)
TUBELINE TL50LSV...
