Hinomoto E2004
/ Hinomoto E2004 #1
hurricane10
Hinomoto E2004
About a month ago my tractor got hard to start it was very slow to get up to speed when starting. After started it would run ok. Then last week I had to hold the starter on until the engine got running, it seemed low on power and after about 5 minuets black smoke came out and it stop'ed and won't restart. I removed lines from injectors and very little fuel squirts when you run starter. Could it be the injector pump or the fuel injectors ? When I loosened the fuel supply line on Injector Pump lots of fuel flows and filter is ok. If its the injector pump where can I get one. I live in Monticello, Fl
/ Hinomoto E2004 #2
I'd have the injectors tested before looking for a fuel pump
/ Hinomoto E2004
I found the problem the head gasket blown. What will this cost to fix ?
PT 28' Peanut Wagon (A64127)
PT 28' Peanut...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
213207 (A64277)
213207 (A64277)
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
