hinomoto e182-help please with starter
   / hinomoto e182-help please with starter #1
davisjames
Yes, you guys that helped out earlier and said that my problem might be the starter were correct. I had the starter rebuilt by a starter shop, installed the starter, but when you try to reconnect the positive cable to the battery, the starter engages as if you were trying to start the tractor. All hookups are secure. Called the starter place and they said it might be an ignition problem. I don't buy it because I didn't have an ignition problem before. Anyone have any thoughts?
   / hinomoto e182-help please with starter #2
Sounds as though your solenoid positive is grounding internally, or maybe one crossed wire??
If it were me (I have done this before:)), I would wire the battery and cables up and make sure everything is hot and grounded EXCEPT the starter. Operate your key switch and watch which wire lights up at the Start, Run and Off positions (VOM or test light).
I don't buy the ignition problem either...but it just might be ignition wire problem /forums/images/graemlins/grin.gif.
Good luck,
Mark
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
UNUSED AGT LRT23 STAND ON SKID STEER (A51247)
UNUSED AGT LRT23...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
2004 GMC Envoy SUV (A51694)
2004 GMC Envoy SUV...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
