Oil & Fuel Hinomoto E152
/ Hinomoto E152 #1
Meaux
Ruston, La.
several makes
What oil and how much in the injector pump for this Hinomoto E152?
/ Hinomoto E152 #2
Perhaps an ignorant question but does your injector pump have a separate oil reservoir? I guess you at least think it does or you wouldn't have asked the question. I've never encountered such a thing and just always assumed the crankcase lube oil system serviced the pump mechanism as required.......
/ Hinomoto E152 #3
Meaux,
I replied to your PM with information that at least on a Jinma (Chinese) the fuel pump does have an oil reservoir. Learn something new every day! The advice there was:
"There should be a mushroom shaped device on top, it's the vent/fill plug. Some models have a tiny dipstick. Absent a dipstick, others have a 2nd plug on the side. Remove vent/fill plug and bottom drain plug. Drain, replace bottom plug. Remove side plug. Pour in lube oil till it comes out the side. Stop pouring, replace side plug, replace vent/fill plug.
I use ISO100 compressor oil (30W). Assuming you use 15W40 engine oil, that's fine too."
ALLMAND  MAXI LITE 2 V (A67714)
ALLMAND MAXI LITE...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
2008 FORD F-350 UTILITY BODY (A66091)
2008 FORD F-350...
2017 KENWORTH T880 (A67714)
2017 KENWORTH T880...
2021 Unused Paladin QH1 3 Point Quick Hitch Tractor Attachment (A66734)
2021 Unused...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
