Oil & Fuel Hinomoto E152
   / Hinomoto E152 #1
Meaux
Ruston, La.
several makes
What oil and how much in the injector pump for this Hinomoto E152?
   / Hinomoto E152 #2
Perhaps an ignorant question but does your injector pump have a separate oil reservoir? I guess you at least think it does or you wouldn't have asked the question. I've never encountered such a thing and just always assumed the crankcase lube oil system serviced the pump mechanism as required.......
   / Hinomoto E152 #3
Meaux,
I replied to your PM with information that at least on a Jinma (Chinese) the fuel pump does have an oil reservoir. Learn something new every day! The advice there was:
"There should be a mushroom shaped device on top, it's the vent/fill plug. Some models have a tiny dipstick. Absent a dipstick, others have a 2nd plug on the side. Remove vent/fill plug and bottom drain plug. Drain, replace bottom plug. Remove side plug. Pour in lube oil till it comes out the side. Stop pouring, replace side plug, replace vent/fill plug.
I use ISO100 compressor oil (30W). Assuming you use 15W40 engine oil, that's fine too."
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2013 Ram 4500 Versalift Bucket Truck (A50323)
2013 Ram 4500...
NEW Woods Reverse Rotation 5ft Tiller (A52748)
NEW Woods Reverse...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2013 Dodge Journey SUV (A50324)
2013 Dodge Journey...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
