Hinomoto 2304 4wd
   / Hinomoto 2304 4wd #1
klawson44
Virginia
I recently picked up a 4wd 2304, it's a great tractor, I have one question concerning the front drive unit. the tractor has 850 hours on the meter and is in great shape however there is about 1/8" of slack front to back in the pivot point of the front axle. Is this a problem?? Should I be concerned?? Any advice or am I just over reacting?? thanks for any help you can provide..
   / Hinomoto 2304 4wd #2
Some tractors this is adjustable.I don't know if yours is.
If there is a large bolt on the front side of the pivot joint,loosen the jam nut,tighten the bolt then back it off about 1/2 turn,retighten jam nut.
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2022 PETERBILT 579 DAY CAB (A53426)
2022 PETERBILT 579...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Elgin Pelican Street Sweeper (A51691)
Elgin Pelican...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
