Hinged mower deck
   / Hinged mower deck #1
g0liath
Ottawa, Ontario
Kubota B2920, MF 35 Diesel
Just wondering if anyone has done or seen or thought of converting their 2 blade 48" or so mower deck from a fixed one piece deck to a hinged or articulated mower deck?
What I'm trying to solve is the issue of uneven ground. I feel the mower would do better if one or both mower compartment/blade could move up/down independent of the other as your mowing across different terrain? Example: ditches that have a high side and then flat, etc..
Anyhow been thinking about this for a while and can't seem to find much/any information online. Thanks.
   / Hinged mower deck #2
Welcome to TBN
Interesting concept. Any thoughts how you would power the two blades? Hope you get some good ideas how to do that.
When I mow a ditch, I run one side of the deck in the ditch. Going back, keep that side in the ditch and don't overlap the mower cuts.
   / Hinged mower deck
I think you might still be able to use the current belt drive and pulley system as long as the angles aren't too crazy.
I do the same thing as you for the double pass, issue I have is that guaranteed, you're digging into the ground one direction or both because of the angles your cutting. That's what I'm trying to avoid. Thanks and I appreciate the feedback!
   / Hinged mower deck #4
A pic or two of what ground you are trying to mow and how your deck digs in would help to better understand. I have a 54" deck w/three blades.
A pic of your mower deck will give us some idea what you want to hinge. Am thinking you will end up with a skipped strip of non-mowed grass. But interesting idea.
1992 Peterbilt 377 Sleeper Cab (A53472)
1992 Peterbilt 377...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Electric Concrete Mixer (A51573)
Electric Concrete...
2019 HINO 268 26FT BOX TRUCK (A52576)
2019 HINO 268 26FT...
