Hillside houses
/ Hillside houses #21
We are planning on building a hillside house also, on this land (attached photo) in New Mexico. The slope faces south, and water runoff will not likely be a problem for us. We hope to build with ICF's but are still in the wishful thinking and trying to figure out what we really want stage.
/ Hillside houses #22
Scesnick, although I've never seen it done yet, moving houses on the island or mainland here is pretty common and we have a couple companies who do it within an hour's drive. It started as a natural progression from jacking up heritage buildings to remove the old foundations and build new ones that complied with the codes for earthquake resistant construction. The foundations of these old building is sometimes pretty ropey. For example, I have a 1920's cottage on my property which is built off of timber piers that have been scorched on the surface, I presume to prevent insect attack (replacing these foundations is a future project).
The procedure for moving the house is to unbolt the wall plate from the concrete underbuilding walls then knock holes in the underbuilding walls immediately below the line of the floor joists and perpendicular to them. Through these holes they thread big, steel beams, spaced every every few feet. These beams are then hyraulically jacked up at either end to carry the ground floor joists (which, in turn, support the external walls) and large, wheeled dollies slip underneath the ends of the beams where they project out the ends of the house. The beams are then lowered onto the dollies and a large tracked excavator tows the house to its new location.
The house is normally left up on the hydraulic jacks at the new loation until the underbuilding walls are constructed below then the company comes back and lowers the house onto the new walls. This is to ensure the house properly lines up with the underbuliding walls.
I don't even need to remove the furniture. The house can be moved with everything in it although breakables will be boxed and we'll remove paintings, etc. from the walls. Temporary service connections can be made for drainage, water, power, at the new location so we can live in the house continuously before and after the move, while the underbuliding is being constructed. The company will be here three days - one day to prep., one to move then a final day to lower the house and haul away the remainder of their kit.
I have to do some bracing work where we have cantilevered upper floor sections but other than that, and the removal of a brick chimney which is built off its own foundations, the house seems to be stiff enough to take the move without additional support. The weight of the house has been assessed at about 90 tonnes.
The cost to move (exluding foundations and services) is $16,000 CAN. plus another $800 or so for the tracked machine. Site prep. and new septic tank (which we're then connecting into the existing tank and field which is only about 14 years old) will cost around $7k and I've the cost of services and foundations over and above. Services trenches I'll cut myself with the 'Bota and I expect the foundation costs to be within the $20k range so I should move the house and have it ready for occupation for around $45k CAN - under $40k US. Add on landscaping costs and the new road (which I'll also do myself) probably amounting to another $30k CAN or thereby.
I've had the uplift in value from moving the house and relandscaping assessed and it's considerably in excess of the cost and effort of doing the work.
I'll certainly take shots as the preparation work and the move get under way and post them on tbn.
/ Hillside houses
Thank you all for the response,Scesnick congrats on running A .I never could make it out b.
/ Hillside houses #24
We planned our home that was finished 6 years ago with a walk out basement. We have never regretted our decision.
/ Hillside houses #25
We have a lot that is sloping and plan to build a ranch style with walkout basement. Here's a rough picture of the front(still in planning, so don't knock the color scheme /forums/images/graemlins/crazy.gif).
/ Hillside houses #26
Here's a picture of the back. Just like a two story. Lots of windows for bedrooms and family room in basement.
/ Hillside houses #27
RMAL,
You said the your land is scenic. Our house is built on a slope, I won't call it a hill but maybe it is. We are almost on the highest land for a good mile or so. The "low" side of our house is about one foot above grade. The high side is a bit over five feet above grade. Every major room has at least one window that is 8 feet by 6 feet or 8 feet by 5 feet. The rooms that are 5 feet or so above grade have a really nice view and its partly because they are so far up off the ground. That extra height in the house adds something to the view. The wifey and I were talking this weekend and we kinda wish we had built up the "low" side of the house a couple more feet to get the same effect as the "high" side of the house.
Hope that makes sense.
To put it another way, if the down hill side of the land has the view like ours, keeping your living areas with large windows a distance above grade can really add something to your house.
Later,
Dan
/ Hillside houses #28
We're planning to build this year on our property, which slopes to the south. Ours will be a ranch style house with a full walkout basement. The windows and french doors on the lower level will make it look very much like a 2 story house, but the main living level will be the upstairs part. We're going to build with ICF's for sure. The plans are drawn, just trying to get all the financing in order. I can't imagine a nicer design that one that lets you look downslope towards your view.....
/ Hillside houses #29
Having lived with a walkout, it is an agreeable design to me.
However - mentioning slopes and houses, as long as the slope is after the house, it stays agreeable. Lately I have seen many more homes being built in areas that I would not even consider walking on. I cannot imagine water drainage, snow removal, or regular maintenance on some of these lots.
Aesthetically pleasing to the eye, I feel the house should be welcoming one to the surroundings and area. If the house is at a bottom of a hillside, IMHO, one ivites the inevitable invasion of water somewhere, somehow....and the area itself draws attention away from the house.
-IMHO.
-Mike Z. /forums/images/graemlins/grin.gif
/ Hillside houses #30
RMAL,
In the 70's I think they called them Bi-Levels, which is what my parents built. Having lived in a walk out basement or Bi-Level, I can only recomend that you build stairs so that there is a landing. It can get awfully tirig walking up and down straight up flights of stairs. It is much less fatiguiging to walk up a few steps, take a short "rest" on the landing and then finish the uphill climb. Personally I never "rest" on the landing, but it is a pause you make without thinking about. Go up 3 staris, then the landing, make a turn, finish going up the stairs.
I would think on a home that is going get get a lot of going up and own stairs this configuration of stairs would work out best. FWIW...
/ Hillside houses #31
Stairs... a good reason to put the master bedroom on the floor that you spend the most time on. /forums/images/graemlins/grin.gif Another thing to consider is stacking closets above each other on the floors and running the floor joists so that when the time comes that you can no longer do stairs, you can gut the closets, pop the floor out and put in an elevator. /forums/images/graemlins/wink.gif
/ Hillside houses #32
My cousins move houses for a living. In the mid 80's my father hired them to move a house in town. The move was from the base of a hill up to almost the top of the hill. They use two heavy wreckers (one is a backup as only one wrecker does the pulling, the other just takes up the slack incase something bad happens to the other wrecker). Anyway, the house was moved up the hill and placed. It is still standing with no problems at all.
They also moved a house in the next town over (historical house) and all they did was brace the chimney. Didn't have to remove it or anything. I have read recently where some companies are actually moving the basements with the house. They have a way to life the concrete floor and all. I would be worried about this style of move though as I fear the floor and walls will crack in the future once the house is set.
