Hillsboro Trailers
   / Hillsboro Trailers #1
drivadesl
Hudson Valley, NY
New Holland TN-70A, Kubota U-35 Mini-Ex,SCAG Wild Cat, Cub Cadet 109
Does anyone have any experience with the above MFG? I am considering purchase of the 14K lb capacity model 700 gooseneck to move my NH TN-70 with FEL, (bushhog, and disc to purchase later). I'm pulling it behing my F250 PSD. I believe the dealer has a good rep and has been around for years. If anyone can comment on the quality and use of this trailer I would appreciate it. At $7.5K, this is a major purchase. I have never pulled a trailer this large before so any suggestions as to options etc also are appreciated.
   / Hillsboro Trailers #2
I consider Hillsboro to be toward the higher end in quality and price when I have looked at trailers. In general, they make a very good trailer but more expensive than most.
   / Hillsboro Trailers #3
You need 25' of deck space. (not 20 + 5, that just blows)
I have a TN75 on a 25' Econoline tilt, (so the whole 25' is deck space)
I can fill it up with most implements and the FEL. In fact, right now it has a FEL, no bucket, an 8' cutter (which are reasonably short) and it's pretty much within a foot of the back of the trailer.
but a 14k trailer gooseneck on a Chevy 2500HD pulls fine. Your F250 will do fine.
You are right in the weight line (as long as your tires aren't loaded, I suppose I should say that, if your tires are loaded, you could be overweight))
You are going to use ramps a lot, get easy to use ramps.
   / Hillsboro Trailers #4
If their trailers are anything like their truckbeds...They're GOOD...:D
Hillsboro Industries - Aluminum Truck Beds
Thanks for the replies. Yeah I am concerned about the overall length and deck space. I thought the ramps that fold up into flat deck space would solve some of the problem as this makes that 5' usable. Also, folding these were pretty effortless as I didn't want to have to wrestle with them either.
The tilt decks are interesting, I hadn't looked at them. I can see how these may make it a little easier in getting the machine on/off. I would think it would be kinda scary having 3 tons of machine tilting forward though. Maybe Lone cowboy, could share his experiences with this type of trailer. Are there any downsides with this type trailer? Does it affect the location of the axels and maybe handling at all? Thanks.
   / Hillsboro Trailers #6
It's very fast on and off and you get all the usable deck space for the length. You obviously can't put the heavy part with the pin in (not moving) past pivot pin (all the weight is then on the pin). But it's never been an issue. The pivot pin is right in between the axles, so it's pretty easy to load. Mine is not a powered tilt (some are) and it has a cylinder that slows the tilt up and down. Really, not an issue. My wife loves it (no ramps).
Can be very hard to get up when the bed is wet and/or covered in snow (don't ask). Have to get a running start so to say. (could be tires of the tractor too)
However
It rides like crap.
Maybe it's just this one, but man, terrible. If you get it perfectly placed it's fine, but move the tractor 1" one way or the other and it will beat you to death.
See, with a regular trailer, you load the tractor and with a bush hog, how are you going to close the ramps? You need like a 28' or more (with a TN) to get enough clear deck space to close the ramps, then get back up and move the tractor back to get the weight balance right. I dunno, just seemed like a pain to me.
   / Hillsboro Trailers #7
LoneCowboy said:
It rides like crap.
The trailer probably needs a stronger towbar, because it is attached to the axle, and is not welded to the front part of the bed. IT has a longer "free carrying" towbar length than normal trailers.
My TN-70 is roughly 16' from the bucket to just past the rear tires. I haven't bought the Bush Hog yet, but the Model 287 is 10'-6" which puts me close to 27ft. Not sure how much I can lift the bush hog, in order to get the ramps lifted onto the beavertail. I will be talking to my dealer tomorrow, and try to see what he recommends. Hopefully they make a 28'. I'm sure they would make any length I need within reason, but I'm not looking for custom pricing.
   / Hillsboro Trailers #9
drivades,
I have an Anderson G82910TW which I pull with a Chevy 3500 Dura Max - Allison Transmission ... I really like this trailer. If you want to see some dimensions and drawings of various trailers they make if for no other reason than for information go to their site:Get your gooseneck trailer, dump trailer, & others - Anderson Manufacturing. and then ... select the type trailer you are interested in and that will take you to a page about all those trailers ... select the model and that will bring up a PDF with info and line drawings ...
Leo
   / Hillsboro Trailers #10
well, i haven't noticed any real difference in price (so much more per foot), no real "custom" prices. They don't seem to care much
BUT
longer trailer is a heavier trailer, meaning you can tow less.
TN series tractors aren't light, neither is a big old bushhog.
just a thought for ya.
2020 KENWORTH T680 (A52472)
2020 KENWORTH T680...
2014 MACK CHU DAY CAB (A52472)
2014 MACK CHU DAY...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
