Higher chance of equipment damage during frigid temps?
   / Higher chance of equipment damage during frigid temps? #11
I don't have any scientific evidence to back up my thoughts, but I tend to agree with the OP, that more metal cracks and breaks during extreme cold. This has been my experience, and to me makes sense as the colder a piece of metal becomes the more brittle it becomes.
   / Higher chance of equipment damage during frigid temps? #12
In the recent below zero temps and the wind blowing 30 mph, I'm more worried about pneumonia than breaking the tractor....no cab of course. Didn't want a cab. Thus, I waited until things got better to deal with the snow which wasn't all that deep anyway.
   / Higher chance of equipment damage during frigid temps? #13
I leave my equipment alone when it is very cold and park my self in front of the fireplace. I don't wan't to risk damage to myself or the equipment in bad weather.
   / Higher chance of equipment damage during frigid temps? #14
The only time I ever broke a 3 pt lift arm was clearing snow at -10°F. Fixing it was also the only time I ever had a ratchet head split in half too.
Just based on memory of that day I opted to clear our 16" snow at 0°F with 30 mph winds on Monday instead of waiting for the -12°F on Tuesday with slower winds. I was still concerned about damaging something at 0, but the job had to get done. Temperatures above 10 make me feel much better.
   / Higher chance of equipment damage during frigid temps? #15
When the job has to "get done", that's a different story. That's what my Carhartts are for. The equipment/tractor will have to do it or bust.
   / Higher chance of equipment damage during frigid temps? #16
Any piece of equipment will break if it gets used, that's part of the game. I don't buy the theory that steel is weaker or more brittle in cold weather, been working with it all my life and never seen anything to convince me of that. I do believe rapid heating caused by engines starting and or running hard, and mechanical systems operating causing heat do cause distortion and can cause stress cracking or part failures. I do think all mechanical systems work harder in cold weather. Oils and Grease are harder and offer less lubricity. Engines work harder, pumps work harder, pressures run higher (thick oil results in higher hydraulic operating pressures), hoses are stiffer, wires are stiffer. I have witnessed more breakdowns and maintenance costs in winter. At my paying job we work regardless of weather, it is not un-common to spend 2 hours in the morning getting equipment running and warmed up to run. That in itself seams like a huge waste to me. On our farm the only equipment we use regularly if its below 0f is the loader tractor to feed out and clean out. That gets parked inside (seldom below freezing) and plugged in. If we didn't work below freezing temps we would be out of work 3 months a year or more though. Here at the farm, as long as its above zero we go to work as needed. I do start the equipment 30 to 60 minutes before I need it to circulate and warm the fluids before we use it.
   / Higher chance of equipment damage during frigid temps? #17
Not trying to be a wise-guy but you first 2 sentences seem to be contradicted by the rest of your post. I kind of guess you concur.
   / Higher chance of equipment damage during frigid temps? #18
I agree cold weather is harder on the operating systems of a tractor, what I don't agree with is that cold steel is weaker than warm steel. I don't think a part will bend or break any easier at 0 than at 70, unless there is rapid heating or cooling causing stress or distortion of the member. When I say rapid cooling I am talking more drastic than going from a heated cab to outdoors, more like operating engine temps to sub zero. I am a huge believer in engine coolant heaters for that reason. I have worked with steel in construction for well over 20 years and it has the same strength properties over the entire range of atmospheric temperatures.
   / Higher chance of equipment damage during frigid temps? #19
I leave all my equipment in the barn unless I have to get it out for a very, very, good reason. I dont know if it changes the properties of metal or not but I know it affects everything else on the machines.
   / Higher chance of equipment damage during frigid temps? #20
I have an open tractor, and my prothesis on my left leg stub gets really cold. I try not to work on the tractor in real cold weather.
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
15ft Aluma Craft John Boat with Trailer (A57453)
15ft Aluma Craft...
Eagleline 3pt 8' Box Blade (A57149)
Eagleline 3pt 8'...
2015 Polaris Ranger 570 (A57149)
2015 Polaris...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A58376)
UNUSED LANDHONOR...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
