High temp grease in gearbox?
   / High temp grease in gearbox? #11
I've no experience with using grease in gearboxes but high temp grease would have a tendency to channel meaning that if you packed a gearbox full of high temp grease once the gears turn they would push aside excess grease that is in the way and create a open channel to run through..
The additional grease would provide no benefit.
A lightweight grease that would flow in & around the gears when it warms up would seem to be the better choice in my opinion.
Actually I do recall years ago that regular grease was used to hold roller bearings in place for assembly when a full complement of rollers was used (no cage to separate and contain them) in a transmission lubricated with oil. This resulted in failure because it blocked oil channels and prevented the oil from reaching the bearing.
Vaseline is used in the assembly of transmissions with a full complement of rollers because it melts at very low temperatures and allows lubricant into the bearings.
90cummins
2757 (A55787)
2757 (A55787)
2018 INTERNATIONAL 4300 SBA 4X2 26' BOX TRUCK (A57192)
2018 INTERNATIONAL...
1678 (A57192)
1678 (A57192)
Informational Lot - Financing (A55315)
Informational Lot...
2021 Chevrolet 1500 Silverado Crew Cab 4WD Pickup Truck (A55852)
2021 Chevrolet...
204923 (A57192)
204923 (A57192)
