High pitche sqeal from engine when starting
/ High pitche sqeal from engine when starting #1
Trace33
NY State
Kioti CK30 HST
Sure this has been posted before but I can't find a reference to the subject.
When I start my 09, 300 hrs, CK30 I get a high pitch squeal from the engine. When I lower the RPM to minimum the squeal disappears. Whether hot or cold engine.
After a few seconds I can increase the RPM or when I raise the FEL the squeal is usually gone. Fanbelt?, any ideas?
Trace
/ High pitche sqeal from engine when starting #2
Yes , first thing to check is the belts.
/ High pitche sqeal from engine when starting #3
Mine does it sometimes too. Probably a pulley or the alternator on its way out.
/ High pitche sqeal from engine when starting #4
Have you ever adjusted the fan/alternator/crank pulley belt? I have an 2004 CK30hst. Mine stretched pretty good when newer needing yearly adjustments. After 12 years, it was time for a new one being no more adjustment left. The belt is rather small in size but only runs the alternator and water pump/fan. It's a metric size and hard to match up in a parts store. Easy adjustment from the alternator bracket.
/ High pitche sqeal from engine when starting #5
Yes, the belt to alternator would be my first check too. Often the alternator will load, to charge the battery after starting and that cause more resistance to turning and the belt slips.
I once had a squeal only when starter was engaged, it was the starter bearings.
/ High pitche sqeal from engine when starting #6
Classic symptom of loose Alternator belt...
Adjust or replace.
Report back for others' future reference.
Adjust or replace.
Yes indeedy that was the problem. Almost an inch of play when I pulled on the belt. Loosened the alternator swing arm, stuck a crowbar between engine and alternator, a slight pull, alternator moved about half inch, retightened the swing arm bolt and squeaky is gone.
Thanks to all who responded. I suspected the problem from the start but a bit of reinforcement from knowledgeable minds calms the nerves. In the past we used to rub a bit of paraffin wax on the side of the belt. Worked for awhile but from a hand's point of view - it's scary down in there.
BTW how in the **** would you get the belt past the fan if replacement was necessary. Looks like a pretty tight fit in there.
/ High pitche sqeal from engine when starting #8
You can get a belt with a smaller diameter over the fan by going between the blades down to the hub with the top, put as much behind the fan on the way down, then push it up to the hub on the bottom and work the other side over. Kind of hard to describe but will be obvious once you see it.
/ High pitche sqeal from engine when starting #9
I wrote the procedure up for a Kioti owner here:
http://www.tractorbynet.com/forums/kioti-owning-operating/385708-fan-belt-ck-25-kioti.html
In the 'past' Generator belts ran looser and were wider. In the 'now' Alternator belts run tighter and are narrow with less contact area on the sheaves to handle the higher loads - thus squealing, from slipping, if not tight.
/ High pitche sqeal from engine when starting #10
Is your battery original? If so it is prolly on it's way out of this life. It most likely gets deeply discharged during starting which is putting a heavier load on the alternator to charge it back up again. And of course, a bad belt doesn't help either. B.
2011 Takeuchi TL250 Compact Track Loader Skid Steer (A64553)
2011 Takeuchi...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
John Deere 148 Loader with Brackets (A65640)
John Deere 148...
Troy-Bilt Pony Riding Mower (A65579)
Troy-Bilt Pony...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
