Snow High Pitch squeal on GC2410 after tsrtaing
   / High Pitch squeal on GC2410 after tsrtaing
Thanks i will check
I have fou8nd the problem
it was a simple problem
A mouse had made a home in air filter . It was alive when a first started the engine the engine was trying to pull it in and it was trying to get out it died in there and was stuck
I removed it all replaced the air filter and all was good
   / High Pitch squeal on GC2410 after tsrtaing #13
Unhook your RPM/HOURMETER and I bet it quits. Its a known problem with these machine. Mine just stay unhooked till temps stay above the 50's. I just unscrew it where it goes in the dash, right above the battery. Then tape the nut so it doesn't slide down the shaft. Should only happen in freezing temps. People have tried changing the grease and oiling the cable but as far as I know there is no cure.
Rich
   / High Pitch squeal on GC2410 after tsrtaing #14
Lol,, gotta watch that. They LOVE air filters. I had one building a nest in the filter box on my GC within days of bringing it home. I check it often now.
METAL TRAILER FRAME W/ AXLE (A52708)
METAL TRAILER...
2298 (A58376)
2298 (A58376)
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2265 (A58376)
2265 (A58376)
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
