Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,316
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Sudden Loss Of Oil Pressure - 2007 Chevy Silverado Vortec 6.0L - YouTube
Sadly I think it may be my pressure relief valve in the oil pump since multiply restarts when it is hot so far has brought the PSI back up. So far when cold the OP comes up and works fine but reading tends to go high with high RPM which would be expected if relief valve is sticking.
Per web the most common fix is changing out the sending unit. After we pull PSI with a manual oil pressure gauge the guessing can stop I guess. May do that this evening.
My neighbor that I always talk about on here had this very issue on a Caddy with a V8. I believe it they had to pull the motor or loosen it to get at it due to the close quarters.
Chris
