High flow hydraulics to FEL
   / High flow hydraulics to FEL #1
tinygiant
Nashville
Kubota M7060
I own a Kubota 7060 that runs 11-12 gpm. I'd like to have the option to run some skid-steer attachments that require a flow closer to 22-25 gpm. Can anyone point me at a recommended product (like a PTO hydraulic pump, or even something that could be mounted permanently, if it exists) for this model tractor? Anyone with experience on the good/bad of a similar setup?
Thanks!
   / High flow hydraulics to FEL #2
Grainger has a pto pump that does 22.1 GPM for close to a grand. If you can drop your request down to 21Gpm you can get one for about 1/4 the cost. Of course you will also need a reservoir, and hoses.
   / High flow hydraulics to FEL #3
You can buy self contained hydraulic units that run off a 540 PTO, but they aren't a cheap date.
Thanks, will start looking ...
   / High flow hydraulics to FEL #5
What I did is pto pump from surplus center not sure what gpm a 40 gallon fuel tank I mounted on my box blade it's permanent now. Because my tractor had a lever for either hydraulics or 3point not both at same time now I have 3rd function front end loader hydraulics and 3 point at same time with top and tilt. Have about 1500 in the hydraulic setup also upgraded joystick controls for float mine originally did not have
   / High flow hydraulics to FEL #6
Most skidsteer hydraulic motors that size have a supply line, unblocked return and case drain back to tank. Three lines. Tank size and cooler depending on application. Tractor loaders aren’t nearly as stout as skidsteers.
   / High flow hydraulics to FEL #7
There are a few commercially available "power packs" like this, they have 14 and 21 GPM options:
Of course then you will need large and expensive hoses, couplers, and fittings to get the fluid up front where you need it. Possible? Yes. Practical? Only you can decide.
   / High flow hydraulics to FEL #8
Another Power Pack:
Thanks, will look at that one also.
Anyone have experience with the IronCraft Hydraulic Power Pack? 21gpm, fewer bells and whistles. How important is the cooling fan? The assumption is I'd be running skid streer implements such as brush cutters, trenchers and the like.
Thanks,
Ed
   / High flow hydraulics to FEL #10
Cooling will most likely be required if running continuously in the summer.
2000 Ford F-450 Pickup Truck, VIN # 1FDXW46F5YEA89140 (A54865)
2000 Ford F-450...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
Kubota ZG327 (A50120)
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
