HIgh flow error 29-03??????? Toolcat 5610 F-series
   / HIgh flow error 29-03??????? Toolcat 5610 F-series #11
:thumbsup:
Repair completed. Was not that bad. Joystick did not have to come off. Side access cover on passenger side, console and top access cover under console had to come off. They slid over the joystick. New solenoid was slightly different and had to grind down plastic hold down nut and use a different o-ring in order for threads to have adequate bite. New solenoid did not have a recess ground into it. Works fine. I must've hooked something up wrong the first go around because PTO would not work and got error 50-78. Took things back apart (just wires on console switches) and reattached everything. Did not find my error, but after that all is well. Error code went away. BTW resistance on new solenoid was about 10 ohm. Old was shorted and read 3 ohms. Good to have the old girl back working properly. I use the 5610 for everything. Probably need to have a backup machine like a v417 or a t190 as well......
Get a service manual. Worth every penny of $20.
   / HIgh flow error 29-03??????? Toolcat 5610 F-series #13
Thanks hardhat for your update and repair information. :thumbsup:
   / HIgh flow error 29-03??????? Toolcat 5610 F-series #14
------------------------ Probably need to have a backup machine like a v417 or a t190 as well......
Good to hear of your fix.
If you get a V417 for backup, it might get used more than the Toolcat :eek:
   / HIgh flow error 29-03??????? Toolcat 5610 F-series #15
I’ve run my 90 “ mower on high flow for short periods when I see a heavy spot coming. If I’ve tried to run too long, I’ve gotten high oil temp warning. Mower definitely cuts better on high flow or with the higher flow of my T650.
   / HIgh flow error 29-03??????? Toolcat 5610 F-series #16
We use high flow all the time with the brush hog, but keep the RPMs around 1800 because it is not a high flow brush hog.
Can you hear the Hydraulic cooling fan come on?
   / HIgh flow error 29-03??????? Toolcat 5610 F-series #17
Yeah, my fan comes on. Are you using high flow on bush hog or finish mower? It has been pretty hot on days my temp warning comes on. I’ve just figured the Toolcat is like a lot of Bobcat equipment that doesn’t have enough cooling capacity on high flow.
I’ve run my 72” Bobcat brush mower on high flow, I think it can handle the Toolcat high flow, its not that much higher than standard on my T650.
   / HIgh flow error 29-03??????? Toolcat 5610 F-series #18
7' brush hog:
   / HIgh flow error 29-03??????? Toolcat 5610 F-series #19
I did not think you could activate "high flow" for use on non-high flow equipment.
   / HIgh flow error 29-03??????? Toolcat 5610 F-series #20
That may be true for attachments that also use the 7 pin plug.
At idle with the brush hog spinning, when the high flow switch is pushed you can hear the blades spin faster and the light in the switch stays on.
Kubota F5220A PTO Driven Snow Blower (A55272)
Kubota F5220A PTO...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2016 Hyundai Sonata Hybrid Passenger Car, VIN # KMHE24L18GA041858 (A57453)
2016 Hyundai...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
