High Angle Engine
/ High Angle Engine #1
Wynnefraser
Melbourne, Australia
Looking for suggestions about a 10-15hp size engine with vertical shaft, that can run at a high angel. Is there generally any issue with running a vertical shaft engine at a 45 degree angle or perhaps even steeper?
/ High Angle Engine #2
Look for a pressure lubed engine, they can handle angles better than a splash lubricated one. What is it going on?
Aaron Z
/ High Angle Engine #3
Even on a pressure-lubed engine, the location of the oil pickup may make it work one direction and not the other.
Bruce
/ High Angle Engine #4
Some of the slope mowers out of europe have the engine mounted in a gimbal so it will swing L-R and always stay vertical while in operation. It could be a tricky situation if trying to do belt or direct drive though.
If thats too much you could try a swinging pickup which some engines use as well.
Heres a machine thats rated for 55* called the RoboGreen. Isuzu diesel powered. Unsure what modifications were made to the engine, but it doesnt self level, so they must be internal. Likely a mod to the pickup.
/ High Angle Engine
It is to go on a slope mower, and planning direct drive to the blade. Only looking for around 10-15hp, but need the appropriate oil pickup.
/ High Angle Engine #6
On industrial engines you can pick the deep oil pan for 45 degree tilt. Thats all it is, make a deeper oil pan and put the pickup tube down into it.
/ High Angle Engine #7
a two stroke engine could possibly fit the requirement.
/ High Angle Engine
Possible a 2 stroke, but actually having a hard time finding anything. Don't seem too common these days, around 10-12hp with vertical shaft and electric start.
/ High Angle Engine
Not really, the initial power has to come from somewhere and so while hydraulics could work would still need a engine to drive the pump.
/ High Angle Engine #11
My dad has had 2 ultralight airplanes. A Rotax 2 stroke might fit the bill... being 2 stroke you could mount any direction needed. Be worth looking into. They are also widely used in snowmobles.
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
Enclosed Trailer with Lube System (A62613)
Enclosed Trailer...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A65643)
2017 FORD F-150...
Unverferth Perfecta 12 (A64126)
Unverferth...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
