High Angle Engine
   / High Angle Engine #1
Wynnefraser
Melbourne, Australia
Looking for suggestions about a 10-15hp size engine with vertical shaft, that can run at a high angel. Is there generally any issue with running a vertical shaft engine at a 45 degree angle or perhaps even steeper?
   / High Angle Engine #2
Look for a pressure lubed engine, they can handle angles better than a splash lubricated one. What is it going on?
Aaron Z
   / High Angle Engine #3
Even on a pressure-lubed engine, the location of the oil pickup may make it work one direction and not the other.
Bruce
   / High Angle Engine #4
Some of the slope mowers out of europe have the engine mounted in a gimbal so it will swing L-R and always stay vertical while in operation. It could be a tricky situation if trying to do belt or direct drive though.
If thats too much you could try a swinging pickup which some engines use as well.
Heres a machine thats rated for 55* called the RoboGreen. Isuzu diesel powered. Unsure what modifications were made to the engine, but it doesnt self level, so they must be internal. Likely a mod to the pickup.
   / High Angle Engine
It is to go on a slope mower, and planning direct drive to the blade. Only looking for around 10-15hp, but need the appropriate oil pickup.
   / High Angle Engine #6
On industrial engines you can pick the deep oil pan for 45 degree tilt. Thats all it is, make a deeper oil pan and put the pickup tube down into it.
   / High Angle Engine #7
a two stroke engine could possibly fit the requirement.
   / High Angle Engine
Possible a 2 stroke, but actually having a hard time finding anything. Don't seem too common these days, around 10-12hp with vertical shaft and electric start.
   / High Angle Engine
Not really, the initial power has to come from somewhere and so while hydraulics could work would still need a engine to drive the pump.
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2018 HINO SA (A58214)
6ft Teakwood Indian (A57454)
6ft Teakwood...
3410 (A47477)
3410 (A47477)
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2017 John Deere 6120E (A53317)
2017 John Deere...
