Hidden Objects
/ Hidden Objects #1
AGGIE00
Last night we replaced all the chipper teeth on our head for todays job. Right out of the box we hit an engine block hidden under some brush. Took out four teeth on a quick $600 job.
/ Hidden Objects #2
The scrap pice for that engine block won't cover that repair will it. That some bad luck.
/ Hidden Objects #3
That's one of the reasons we only use our chippers in truly virgin areas or swamp where there is way less chance of finding metal. Rocks are one thing metal is another.
/ Hidden Objects
We run a combination of both and it took out two of each. $180 for the two hammers and $100 for the two chippers.
/ Hidden Objects #5
That sucks. Its one thing to ruin teeth on a big job where you have the profit to cover it, but when you do on the small ones it makes you wish you had just stayed at home.
/ Hidden Objects
And now we're stuck with not a single object to winch from. Gotta figure out how to have fun with this.
/ Hidden Objects #7
Depending on the soil, a friend of mine has about 10 mobile home anchors that he screws into the ground when he gets stuck, equally spaced apart and with chains connecting them, and uses that for a anchor point. He has them laid out and connected with the attaching point at the point of a V. Never seen it done, but that is what I understood from his discription. Keeps interlocking chains as tight as possible during installation and the winch bends them till the slack is all taken up. I suggested binders to take the slack out of the chains but he just does his thing.
David from jax
/ Hidden Objects #8
I feel ya a few months back I had a job just like that a four hour minimum job I hit a tranny before I could rise the head up when it hit I blew threw half of it an 13 teeth
/ Hidden Objects #10
Yellowdogsvc has a good idea. On those small jobs, that's when you'll spend more time getting unstuck, flats, and whatever else that's possible. You need to have a (oh,crap clause) to protect your bottom line.:laughing:
/ Hidden Objects #11
but more importantly? what kind of engine block was it?? ( sorry about the teeth... )
/ Hidden Objects
Some old v8 gasser without the heads. Chewed up 3 pistons and too much of the block. This job was for one of my customers that does underground utilities and we do all their construction staking, which is quite a bit. This is one of those situations where you just eat it and smile while it goes down.
/ Hidden Objects #13
kinda like getting a mowing contract and hitting every stump and old tire rim and battery on the side of the road inthe 1' grass that you can find.. :(
best of luck
2022 CATERPILLAR 259D3 SKID STEER (A64279)
2022 CATERPILLAR...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2022 John Deere 520M Loader (A63116)
2022 John Deere...
LANGELIFT 4000# - 30" X 30" HYD LIFT TABLE (A63290)
LANGELIFT 4000# -...
