Hi
   / Hi #1
sgrmtndrone
Mo. Ozarks
2 N
I been a member since 7/06 here & TBN had been a great help with a Izeki TL 1900 I had it is has since gone away but I have recently gotten a 1939 N (3rd owner) and have been checking out the forum . Ya all are great with the advice and look forward to following the treads here now .
   / Hi #2
:welcome: Good luck with the "N" do you have any pictures of her yet we would like to see them.:thumbsup:
   / Hi
   / Hi #4
are you sure she's a 39? 9n?
she's got oval radius rods.. those are a post 1944 option... meaning 2N
she also has the rivited rear hubs.. those are a later option.. but were offered as upgrades or repalcements for he cast solid hubs that broke out due to voids.. so that one is less of a determining factor.
what do date codes on various parts say.. like axle trumpes?
engine sn? ( engines can be swapped.. might have a 39 engine in a 44-46 chassis.
where are the grease fittings on her front spindles? fore or aft?
I also see a thumb interlink start switch.. not an option on the very early units ( nor would steel sheet tin be either ).. also no trans dipstick in the tranny cover.
post back.
   / Hi
Sorry been busy and just got back in here . I think you may be right about different parts/years . I'll check it all out lol .
   / Hi #6
post back what ya find. if you have questions.. take pics and post them..
   / Hi
Grease fitting are aft on the spindles , the only # I can make out on the block is above the starter and is 1256
   / Hi #8
earliest units had the grease fittings forward.
the 1256.. is it below the head on a 1x4 flattened boss?
   / Hi
I seen those #'s but can not make them out I may see about getting the wife to check them as my eye's are not what they use to be .
   / Hi #10
rub some chalk or crayon over them then wipre with a clotth.. us e bright light too..
2009 Volkswagen Jetta Sedan (A51694)
2009 Volkswagen...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A51248)
UNUSED FUTURE SB45...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
UNUSED FUTURE FT-HJ6 HD STORAGE SHELVES (A51248)
UNUSED FUTURE...
JOHN DEERE 560M LOT IDENTIFIER 15 (A53084)
JOHN DEERE 560M...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A51247)
UNUSED CFG...
