Hi New to Tractor by Net
   / Hi New to Tractor by Net #1
Antlerbob
Spring, Texas
Kubota Diesel G5200
Hi, I just wanted to introduce my self I'm new to this forum. My name is Robert and I live in Spring, Texas which is located in the Northwest part of Houston, Texas. The reason I joined is because I recently purchased a Kubota G5200. I know nothing about the unit yet, except that the D600 runs strong
and the over all condition of the tractor is about a solid 7 out of 10. The mowing deck has seen better days and I will need to grind and wield in some really nice size hole. The deck I would rate at about 4.8, which to me basically means border line salvageable. I didn't pay much for the unit so I don't mind spending a little to have the deck repaired.
First thing I need to do is change the engine oil and maybe the glow plugs. Does anyone know or can suggest a type of oil to use in this little 3-cylinder Diesel? Also, If you know what the part number is for the oil filter that would be great! Thanks !
   / Hi New to Tractor by Net #2
Hi Robert. Welcome to the forum and congrats on your Kubota! :thumbsup:
I'm going to move your thread over to the Kubota section to see if we can find you some answers.
   / Hi New to Tractor by Net #4
Hi. Welcome.
I use Rotella T6 in my BX. Works great and starts easy in winter too. Engine runs real quite.
I do not have the filter number but you can find that at Messick's website.
Good luck with the project to get it up and running the way you want.
   / Hi New to Tractor by Net #5
You can't go wrong with Rotella T6 engine oil...
Why do you suspect a glow plug problem, they are just resistant Heaters used Only for starting. KennyV
   / Hi New to Tractor by Net #8
Yup- Rotella T-6 synthetic oil. Easy to get a any Walmart, reasonable priced- what else could you want?
   / Hi New to Tractor by Net #10
Welcome aboard, Robert!
The G5200 is one tough bug. I'm patching holes in my RC44 deck this weekend. Lots of daylight coming thru.
Engine oil (per the operator manual): 3.2 qts (CC,CD, E or F)
Above 59 [deg F] = SAE 30 or 10W-30
Below 59 [deg F] = SAE 10W-30
Oil Filter: HH152-32432 (replaces 15841-3243-1)
Unless you know that these items have recently been serviced, I'd also replace:
Fuel filters (one on or near the engine & one behind the right rear tire)
HST oil & filter & clean the screen.
Mower deck GBX oil (90W).
Radiator fluid & give it a good flush.
This is important, as these Gx200H models are prone to overheating!
Pull the radiator screen & clear it before & after every time you mow.
Make sure the temperature gauge is working correctly.
There should be a steam whistle attached to the coolant overflow hose - check that it works.
Enjoy your wee beastie - it's a great machine!
-Jim
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
UNUSED FUTURE FT850J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
Michigan L-90 Wheel Loader (A52384)
Michigan L-90...
