Hi,New member here, with a log loader problem.
   / Hi,New member here, with a log loader problem. #1
badgascoupe
peru,maine
JD 540 A skidder
Hi,Well found this sight while looking to solve a hyd problem with a log loader. I have a Prentice extendaboom loader,originally a sheetrock loader.Put the loader on a 3 axle Mack. I took off the rock forks and added a grapple. Here's the problem,all the loader functions operate off their seperate spools on the valve body,however the grapple dosen't have enough pressure to hold the log.I had the grapple cyls repacked still same issue.Any ideas? Thanks,Sean
   / Hi,New member here, with a log loader problem. #2
What kind of pressure do you see on the grapple.
If you resealed the cyl, then you may need to replace the valve. If it is a stacked/sectional valve, you can replace each section.
Switch spools and check the pressure.
   / Hi,New member here, with a log loader problem. #3
Check the grapple spool and see if it has it's own reliel valve. All the spools could have there own relief valve.
   / Hi,New member here, with a log loader problem. #4
Does the grapple leak open under load or will it not close with enough force to lift the logs?
If it leaks open under load then you could have a leaking spool. Installing a load holding device like a P.O. check or counterbalance could solve this problem.
If not enough force you will need check system pressure if it is as rated specs for your machine you will need do one of the following:
increase the cylinder sizes
chnage mechanical linkage so that is provides more clamping force
Hi JJ,it has a greshen 6 spool stacked valve.I have moved the grapple lines to different spools on the body as it would creep closed in its regular valve location.At other spools on the valvebody it opens and closes correctly and dosen't creep closed.I replaced 2 power side fittings coming out of the pump to the valve body with ones that have a port to add a pressure gauge to them,Graingers had to wait a day to get the gauge for me.
Hi Oldnslo,The grapple valve creeps closed when you let go of the handle.I moved it to other spools and it works correctly( stays where you stop it) other then not enough pressure to hold logs.Plumbed in elbows with ports to add pressure gauges to it,waiting on Grainger for the gauges.
   / Hi,New member here, with a log loader problem. #7
You have a worn spool, just replace that spool section.
JJ, I did notice it has 2 washers behind the spring on that spool. Thanks,Sean
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A54607)
2019 HYUNDAI...
2021 CASE 580SN WT (A47477)
2021 CASE 580SN WT...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
2015 Hitachi PC138 (A47477)
2015 Hitachi PC138...
2017 Ford Explorer SUV (A53424)
2017 Ford Explorer...
