Hi my name is Hammick and I'm an over-greaser
   / Hi my name is Hammick and I'm an over-greaser #21
You might want to attend An OGA meeting. I think they are held at TSC on Thursdays :D
   / Hi my name is Hammick and I'm an over-greaser #22
I typically pump it in until I see new clean grease coming out one point or another. I like to wipe away excess blobs that seem to just collect dirt and grime also. It helps to keep the tractor neater looking and less likely to get greasy with everything you touch.
I have been using Lucas X-tra heavy duty grease for construction equipment, farm tractors, etc. It seems to work well in heat, cold, water etc. Green is good!!
   / Hi my name is Hammick and I'm an over-greaser #23
Keep your loader pins greased. You don't want to know about replacing wallowed out bushings and new pins. Most all smaller loaders will have steel pins and bushings and lack of grease will quickly oval the bushings. Just did the loader on my second hand 2002 M9. If I didn't have the machine tools to line bore the old bushings and then weld in new ones, it would have been super expensive. As it was, I had to completely take the loader apart to do it.
One pin on the left lift cylinder was dry:eek: It would slide side to side but thankfully had no radial play.
Some how I had never greased that zerk because of its angle it was difficult to get the grease gun to stay attached[no locknlube].
I did manage to pump it full which tightened it right up.
   / Hi my name is Hammick and I'm an over-greaser #24
You were lucky to catch it when you did.
   / Hi my name is Hammick and I'm an over-greaser #25
Better an "overgreaser" than an "undergreaser" I say.
   / Hi my name is Hammick and I'm an over-greaser #26
Okay Greasers... a couple questions.
1. Do you run the tractor and operate the moving parts during greasing to help it come out of both sides?
2. Do you pull the pins ever to see if you can... and check that they are in good shape?
I'm not ready to admit I have a greasing problem.
   / Hi my name is Hammick and I'm an over-greaser #27
One quick note on lawnmower spindles. The bearings are sealed on both sides and do not get any grease when you grease the spindles. You are on;y filling the cavity with grease. If you want to grease the bearings, remove the inner plastic seal on both top and bottom bearing to allow grease to get in.
   / Hi my name is Hammick and I'm an over-greaser #28
I just grease it till I see it coming out and leave the extra grease , Then it falls off in the driveway I step on it and track it everywhere.........:rolleyes:
   / Hi my name is Hammick and I'm an over-greaser #30
450
LANDHONOR BS-12-2500G (2) PRONG HAYSPEAR (A57193)
LANDHONOR...
2011 MERCEDES-BENZ S-Class Sedan (A53424)
2011 MERCEDES-BENZ...
49205 (A55788)
49205 (A55788)
ALLISON TRANSMISSION (A55745)
ALLISON...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
2023 Vivid EV Electric Cart (A55853)
2023 Vivid EV...
