Hi, I'm needing advice on a John Deere MX 8 mower.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #1
Steve E H
John Deere 4020
Hi, I'm needing advice on a John Deere MX 8 mower. I saw this site in my search and thought it may be helpful for a variety of reasons.
Concerning the MX 8 mower, t has a single acting hydraulic cylinder to lift the rear wheels. When the hydraulic cylinder is fully extended, hydraulic oil spews out the plug at the end of the cylinder. I am needing ideas on what exactly could be wrong and what is needed to fix this problem.
Thank you.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #2
I’m guessing it doesn’t have gland seals or very good ones and the rod seals are shot. When you deadhead the cylinder the oil pushes past the worn seals.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #3
:welcome:
Welcome to the forum!
I'm going to move this thread over to our John Deere section.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #4
Don't mean to hijack thread, but related questions: Does the "back side" of a single action cylinder, that doesn't normally see pressurized fluid, need to be vented?
Can a double action cylinder be made into a single action cylinder by using one line? If so, does the "inactive side" need to be vented or plugged?
   / Hi, I'm needing advice on a John Deere MX 8 mower. #5
Thank you.
A pic will help see what you refer to here, but there should be no fluid spewing out.. More specifics will help answer your question.
:welcome: to TBN
   / Hi, I'm needing advice on a John Deere MX 8 mower. #6
A double acting cyl can be utilized as a single acting cylinder by removing one hose & installing a breather.
   / Hi, I'm needing advice on a John Deere MX 8 mower. #7
Ditto cyl piston seals have failed.
2015 INTERNATIONAL DF677 (A52472)
2015 INTERNATIONAL...
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
2008 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2008 Jordair...
ITEM LOCATION (A53084)
