Hi, from West Virginia...
/ Hi, from West Virginia... #1
skidmark13
Glenville, WV
Case 310G
Where you need a bulldozer to survive!
I have a Case 310G, 6way blade, G188D engine. I also have a 310E (4 cyl gas, Ford? )with totally worn out tracks - they will not stay on.
The "G" Runs a little rough and WON'T start without starter fluid. I'm thinking about checking the injector pump timing. I've looked in it and turned the engine over plenty but never see the timing mark pass by the stationary mark.
Finding the flywheel mark is going to be a real challenge.
The left steer/brake isn't too good I guess the drum is worn and I can't get any more tightness on the band.
Fixing a hydraulic cylinder leak tomorrow.
/ Hi, from West Virginia... #3
Welcome. Glad to have you aboard. :)
Chad
/ Hi, from West Virginia... #5
Welcome to TBN!!!
/ Hi, from West Virginia... #7
Welcome to TBN from a fellow hillbilly from WV.:D
Thanks, everybody for the warm welcome. I got the exhaust finished and hydraulic leak fixed. I may have a cylinder missing fire.
/ Hi, from West Virginia... #11
Welcome to TractorByNet from Missouri.:)
Informational Lot - Financing (A63118)
Informational Lot...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A62131)
UNUSED RAYTREE...
1999 Peterbilt 379 Heavy Haul Truck, VIN # 1XP5DB9X1XN487176 (A61165)
1999 Peterbilt 379...
2005 Pequea Trailer Model 716 Deckover (A63116)
2005 Pequea...
FRONTIER RC2060-60" ROTARY MOWER (A62130)
FRONTIER...
UNUSED CFG INDUSTRIAL MH12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
