Hi from MN
   / Hi from MN #1
ynahpetscnb
I am thinking about buying a ferris lawn tractor. Looks like an older one. It has a 22hp kholer motor that souns like it needs a rebuild. Are these easy to find parts for?
   / Hi from MN #2
Welcome to TractorByNet!
I moved your post into the General Lawn and Garden section so our lawn tractor experts can see your thread and hopefully give you some good information.
Thanks for joining!
   / Hi from MN #3
Welcome to TBN,
Which model of Kohler engine is it. Most of them parts are readily available but would want to make sure the block is either cast iron or has cast iron liners in case it needs to be rebored.
If the engine is bad what is the rest of the mower like? Is it a hydro transmission? If yes was it taken care of any better than the engine?
Roy
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
CRAFCO INC. MAGNUM PORTABLE SPRAY INJECTION PATCHER (A54756)
CRAFCO INC. MAGNUM...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
Charlotte County (A50323)
Charlotte County...
