HI Ford 655A owner looking for some help
   / HI Ford 655A owner looking for some help #1
capt2bull
Brewster
ford 655 A
I have a 655A with all the Manuals . but i can not find the Front Differential Fill plug . The Manual says if you are facing the front of the machine it would be to the right side middle of the axle housing just to the right of the pivot bearing . However on this machine it is not there. i did find the drain on the backside but i will not drain it till i can find the fill. i have looked all over so now im looking for help
Thank you
Phil
   / HI Ford 655A owner looking for some help #2
The fill plug is also the level plug. It should be halfway between the differential and steering trunnion on the rear side of the axle beam about halfway up from the bottom. Not sure which side. A hex headed plug either 19 or 17 MM.
Thank you, i will try to look again tomorrow
   / HI Ford 655A owner looking for some help #4
:welcome:
Welcome to the forum.
:tractor: I'm going to move this thread over to our New Holland/Ford section.
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2020 EZ-GO Elite RXV Electric Golf Cart (A50324)
2020 EZ-GO Elite...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52748)
DeeZee Crossover...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
toro turf sweeper (A50324)
toro turf sweeper...
