Hi Everyone, we have a 4835 Ford Newholland, do our own work n looking 4 tech talk.
   / Hi Everyone, we have a 4835 Ford Newholland, do our own work n looking 4 tech talk. #1
pinkpixybug
The Pacific Northwest
Hi, We have a 4835 Ford Newholland, we are using as seppi flail deck mower and we keep snapping the bolts in the back roller, there is a lot of vibration and we cannot figure out what is causing it. how can we get the roller balanced? or figure out why it is vibrating enough to break the bolts on the roller after only cutting on a flat surface for about 100 yards.
   / Hi Everyone, we have a 4835 Ford Newholland, do our own work n looking 4 tech talk. #2
Welcome to TBN. :)
   / Hi Everyone, we have a 4835 Ford Newholland, do our own work n looking 4 tech talk. #3
Hello & WELCOME to TBN!
I moved your thread to the Ford New Holland Owning/Operating Forum. :)
   / Hi Everyone, we have a 4835 Ford Newholland, do our own work n looking 4 tech talk. #4
Some pictures of this implement would be helpful.
Is the pto shaft phased correctly? Phasing is setting the forks of the pto universal joints in the correct position so the shaft does not whip and vibrate. Look at your owners manual for the flail and it should tell you what the correct phasing is.
Is the roller driven? If it is, it may be bent or misaligned. If it's not and it just contacts the ground and rolls at ground speed, that's not likely the problem
Thanks for the reply,
we have modified the stabilizer arms and float the balance with chains.
This has been the way we used it last year and did not have this problem.
the rear roller that is snapping bolts is not belt driven, the flail roller is belt driven and when we get it home tonite we can check the flail roller to see if that is off balance. we figure that if we take all the shackles and teeth off it will reveal whether it is the flail roller or could possibly be the shackles and cutting teeth?
on the pictures comment, I will get some pics when the machine gets home later tonite or in the morning. :)
   / Hi Everyone, we have a 4835 Ford Newholland, do our own work n looking 4 tech talk. #7
headlights wont work
   / Hi Everyone, we have a 4835 Ford Newholland, do our own work n looking 4 tech talk. #8
This thread is +4 years old. You will increase your chances of getting useful responses if you start a new thread with a descriptive title.
Steve
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
1982 S&S FLATBED (A52472)
1982 S&S FLATBED...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
