Hi every one i am berny wont to own a tractor.
   / Hi every one i am berny wont to own a tractor. #1
bnoel10
Fournier ontario
1025r tlb lx176
Soon i will buy a sub compact i need input .
   / Hi every one i am berny wont to own a tractor. #2
berny
tell us how you will use your soon to be purchased tractor.
Snow removal?
Agriculture?
Forestry?
Also, are you budgeted for new or used?
What implements will you need at first?
Hi Cal
Bigest job cutting 3 acres of grass.
Then clean mi driveway
Part of the 3 acres is not level enough so need a box scraper i think, front end loader, snow blower.
Got 4 acres of bush so if there is time left clean up dead trees.
I want to buy new and keep it t'il i am to old to use it.
   / Hi every one i am berny wont to own a tractor. #4
Hi Cal
If you can afford it, get a cab, especially in snow country.
Most of the big names, Kubota, New Holland, John Deere, all make good machines. Other makes might be as good, but the dealer might not be established very well, and those dealers go away. I am partial to Kubota, they make all their own major components, engines, transmissions. I suspect Massey Ferguson might be popular in your area, they make some good stuff, just have to see if you are comfortable with the dealer. I am of the same mind, I don't ever plan to sell my machine. Btw, dad's people came from Quebec. Way back, tho!!
   / Hi every one i am berny wont to own a tractor. #5
Welcome, you wouldn't be related to an Eve Noel ?
Loking in to it ,but for the price can get som one clean mi driveway for ten years.
Still tinking.
Dont tink so .
   / Hi every one i am berny wont to own a tractor. #9
Have set a budget? My first thought is that a BX or similar size in another brand would do you. Smaller tractors generally take more time but not by much if your talking mowing lawn and clearing snow with a blower. When you get into ground engaging work, then traction which means weight, and ground clearance can be important. What will you be doing in the brush? What is the brush like?
johnthomas wrote up a good comparison betwee the BX and B series. If you can find that it might get you started.
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
Set of 4 ST205/75R15 Trailer Tires (A55787)
Set of 4...
2007 BMW 750Li Sedan (A55758)
2007 BMW 750Li...
2016 IZUZU NPRXD S/A BOX TRUCK (A52706)
2016 IZUZU NPRXD...
