HI All! X728 grease point question?
/ HI All! X728 grease point question? #1
BigSexy
Mountain Lakes,NJ
2010 JD x728
Hi All, I recently picked up a 2010 x728. My question is where are all the grease points? I have gone through the machine and replaced the plugs,oil and filter as well as the transaxle filter and changed the hydro fluid front and rear as well as the gas filter and radiator fluid. I have only found the 3 grease zerks in the front steering as the manual states. I've been reading and it seems like it changed year to year in the manuals,older manuals stating more grease points in the rear. Can someone please tell me where the other grease points are?
Thank You!
Pat
I will be having more questions about installing the 60" 7 Iron later
/ HI All! X728 grease point question? #2
You likely have them all.. being as it is 4wd and not all-wheel-steer.
May be a front axle pivot bushing that takes grease, but would need the last 6 digits of your s/n to tell. PM me if you think that would help.
/ HI All! X728 grease point question? #3
G'day Mate and welcome to TBN from Downunder.
You've found all of the grease nipples (zerks)... unless you haven't. :) OEM Operator Manuals have a tendency to not be updated.
Enjoy the site.
Thank You for the replies fellas! I just wanted to make sure that I didn't miss anything.
Pat
/ HI All! X728 grease point question? #5
My x744 and x749 have a zerk for the front axle pivot and the rear engine pto shaft u-joint near the hydro.
/ HI All! X728 grease point question? #6
Yes, don't want to forget those drive shaft U joints. My X748 has two. One is rather hard to get to.
That's exactly what I was guessing ruffdog and ccsial! I could not figure out exactly where the zerk is for the rear. I'm going to do a little crawling when I get out of work today. I appreciate the input!
Pat
/ HI All! X728 grease point question? #8
If you have the deck on, reach up under the tractor about where the leading edge of the seat would be. You should be able to feel the shaft going from the engine to the transaxle.
/ HI All! X728 grease point question? #9
There is one near the front of the tractor and the other near the rear. You may have to turn the shafts to get to the zerks. One shaft will move the tractor when you turn it. The other one is tied to the engine and the engine will turn. At least that is the way my 748 is.
I have to remove the deck to get to them. I jack the rear of the tractor up a bit to get under there and have room to work.
/ HI All! X728 grease point question? #10
Here is ore reading and pictures for x728 grease locations:
Google
Thank You for the replies! I have the deck off, to be honest it's off because I couldn't get it back on. I didn't go back under and grease yet because the weather has been terrible and work has been crazy. I plan on doing it the weekend and hopefully cutting with it the first time next week. I will report back after I go through everything again. Thanks Again!
Pat
UNUSED SDLANCH REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED SDLANCH...
429132 (A61165)
429132 (A61165)
CAT 315F LCR Hydraulic Excavator (A61166)
CAT 315F LCR...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
