Hi all, I am terrible at navigating these things.
   / Hi all, I am terrible at navigating these things. #1
Alabastershame
Case 580c
I recently purchased a 1981 case 580c and it only goes in reverse. I have changed the fluid checked the pick up screen and still just reverse. I am looking at rebuild kits and wondered, given that it goes into reverse perfectly and without slippage is there any reason to replace the converter and pump? Any direction would be appreciated.
   / Hi all, I am terrible at navigating these things. #2
:welcome: to TBN.
You may have better luck seeking info if you post in Case-IH or Parts/Repair section.
   / Hi all, I am terrible at navigating these things. #3
Welcome to the forum!
:tractor: I'm going to move this thread over to our Case section.
   / Hi all, I am terrible at navigating these things. #4
I could easy have typed this also but chuckled at your post due to the last words... "Any direction would be appreciated." Well you have reverse so does that mean you are now, OKAY?
Have you verified the linkage is connected and working? I would begin there. Don't just assume it is shifting be sure any rod is moving as it should when linkage is moved.
Well reverse is nice, :) two directions would be greater appreciated. I took the linkage off and rotated it manually made no difference.
2021 Ford F-150 4X4 Ext. Cab Pickup Truck (A55973)
2021 Ford F-150...
2004 TRAVIS BODY & TRAILER DOUBLE ALUMINUM BELLY DUMP COMBO TRAILER (A58214)
2004 TRAVIS BODY &...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2018 Komatsu D155AX-8 Crawler Dozer, S/N 100205, PIN# KMT0D126PJC100205, Turbo Diesel Engine, 13' (A59076)
2018 Komatsu...
2019 BOBCAT T590 SKID STEER (A52709)
2019 BOBCAT T590...
2015 Kubota KX91-3S2 Mini Excavator (A55973)
2015 Kubota...
