Hi all, I am terrible at navigating these things.
   / Hi all, I am terrible at navigating these things. #1
Alabastershame
Case 580c
I recently purchased a 1981 case 580c and it only goes in reverse. I have changed the fluid checked the pick up screen and still just reverse. I am looking at rebuild kits and wondered, given that it goes into reverse perfectly and without slippage is there any reason to replace the converter and pump? Any direction would be appreciated.
   / Hi all, I am terrible at navigating these things. #2
:welcome: to TBN.
You may have better luck seeking info if you post in Case-IH or Parts/Repair section.
   / Hi all, I am terrible at navigating these things. #3
Welcome to the forum!
:tractor: I'm going to move this thread over to our Case section.
   / Hi all, I am terrible at navigating these things. #4
I could easy have typed this also but chuckled at your post due to the last words... "Any direction would be appreciated." Well you have reverse so does that mean you are now, OKAY?
Have you verified the linkage is connected and working? I would begin there. Don't just assume it is shifting be sure any rod is moving as it should when linkage is moved.
Well reverse is nice, :) two directions would be greater appreciated. I took the linkage off and rotated it manually made no difference.
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
