HF tools that suck
   / HF tools that suck #441
Couldn't be as noisy as the $9 angle grinder .... or is it?
I've never bought one of their angle grinders but others, who have, noted that giving the gears a good glob of grease makes a big difference in noise level.
   / HF tools that suck #443
It's not just the HF grinders, open up any brand and you'll discover that they chinzed on the real grease. Whenever a new grinder came into the shop, they always gave it to me first to open it up and replace the cosmoline for some moly grease and a dollop of Power Punch. That made it a bit stickier, and help it to flow into the bearings that otherwise wouldn't see any lube at all.
   / HF tools that suck #444
Power Punch?
   / HF tools that suck #445
I just remembered a Much Suck HF tool from 10~15 years ago: A rig for mounting an angle grinder to make it a chop saw. Made mostly of thin sheet metal.
You would expect you could force a little weight on it, to the point where the motor rpm dropped a little. However - it flexed so much that there was extreme risk of shattering a thin cutoff blade because forcing it in the cut flexed the chassis crooked instead of loading the cutting edge. I tried clamping it to the workbench to improve stiffness. That didn't help.
Also I just remembered that tightening the built in 'vise' pulled whatever was in the vise up off the table, crooked.
100% a useless pretend tool.
   / HF tools that suck #446
i have 3 of their grinders, 1 cheap one and 2 their best. They all run smooth and take a lot of stress the way I do stuff. I guess; wait and see. I use the cheap one for a wire brush wheel, i for a cut off wheel and the other a 14/grinder disc. They are always on the welding bench.
Ron
   / HF tools that suck #447
Ron
Similar, I have the $9 one, the orange (now red) one, and the blue paddle switch. Wire brush, cup brush or flap disc, grinding disc, respectively. I only use them occasionally, but no problems in the 15 or so years since I bought the first of these. I really should grease them. They clearly don't have the torque of a $100, 11 amp pro tool but they serve me ok.
   / HF tools that suck #448
Sometimes, especially when wirebrushing odd-shaped pieces with a knotted brush, a little less torque is a GOOD thing.
   / HF tools that suck #449
I had the blue paddle switch. It died about a week after the 90 day warranty ran out. Probably the 2nd or 3rd time it had been used.
Went to Lowes and got a MUCH nicer Porter Cable for about 10 bucks more.
24 Foot Wells Cargo Enclosed Trailer (A50324)
24 Foot Wells...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
LEEBOY 8520 APHALT PAVER (A51242)
LEEBOY 8520 APHALT...
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
