Quick Hitches HF 28" Quick Hitch & 20" Attachments; quick fix
   / HF 28" Quick Hitch & 20" Attachments; quick fix #1
raykos
Central Pa.
JD2305
I bought the HF Quick Hitch, not knowing it came in came in two different widths; to paraphrase Mr. Yogi Berra, "...if there's a 50/50 chance, 90% of the time I'll choose wrong..."
I ended up with the 28" wide from HF, and my landscape rake from TSC is 20"; bought longer pins for the rake, but they were just a little short. So, I took two black pipe nipples,(1"x2 1/2") and using a 4 1/2" hand held grinder with a metal cutting blade and a vise to hold them, cut a slot in each nipple. Then, slipped the nipples over the rake pins, and when the rake & QuickHitch are engaged, the edges of the slots, stop side to side movement, and prevent the rake from falling out of the HF QuickAttach.
Don't know if anybody else ran into this problem, but this quick fix works for me.
   / HF 28" Quick Hitch & 20" Attachments; quick fix #2
The "other" HF QH was not 20" but rather 26" or something. The 20" spacing on your LR indicates it is for a CAT0 setup rather than CAT1.
Hustler super Z zero turn (A56859)
Hustler super Z...
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
Ariens IKON 42 42in Zero Turn Mower (A55851)
Ariens IKON 42...
2025 Electric Diesel Fuel Pump with Hose Reel (A55852)
2025 Electric...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500...
