hey guys got sent here with this question to you follow ford owners
   / hey guys got sent here with this question to you follow ford owners #1
Knifer
Bronze Member
Winter Haven
Massey,JD 2010, International W6. '42 case
I'm just going to quote my other thread someone has deciphered that its a 1972 motor 172 or 192
http://www.tractorbynet.com/forums/.../323025-hey-guys-got-my-self.html#post3909930
I have a ford 2000 1964
serial on the tractor says it's a 144 cid diesel
I spun a rod bearing and destroyed the crankshaft. I decide to rebuild and the motor and replace the crank since no one could turn it. Anyway I order everything for the 144 and nothing is right rings too small crank to stroked
So i came to the conclusion the motor has been changed over the years.
I have been trying to figure it out.
it's 4 cyl diesel
Here is the info I have casting number on the block d2nl 6015L
there is also a number stamped by the timing cover d3-jl-607-L
the bore size is 4 1/8 inches
the piston have 2 compression rings and 1 oil ring, the set I ordered had 3/1
I have already dropped a crap load in the parts hoping I can return them.
I really like the tractor and hope I don't have to junk it.
   / hey guys got sent here with this question to you follow ford owners #2
I believe the 144 had a bore size of 3.56 so you can rule the 144 diesel out, they were hard to get parts for anyway. the 172 had a bore of 3.90 and the 192 had a bore of 4.13. I am not familiar with the diesel block codes but i do have three 192 gassers and they all end with a K. So with an L block (not a 100%) but with that bore I would lean towards the 192. I would mic the bore because 1/8 is .125.
Kirk
thanks kirk it does mic out at 4.125- 4.130
seems like everything I find for a 192 is a 3 cyl :thumbdown:
   / hey guys got sent here with this question to you follow ford owners #4
the 192 4 cyl was an industrial application..
know where i can find parts?
   / hey guys got sent here with this question to you follow ford owners #6
have you tried CNH?
2015 Ford Explorer SUV (A51694)
2015 Ford Explorer...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
