Hey! Greg here Ford 1320 4wd
   / Hey! Greg here Ford 1320 4wd #1
gdtoth511
yorktown VA
Ford 1320
Ford 1320 only makes one click then wont do any thing after taking out battery and reinstalling. Charged battery overnight. Same result. Dash lights came on before trying then after the click...nothing. replaced battery terminals and have 12v at starter. ( I accidently reversed polarity on battery connections and saw a little smoke...oops. Any suggestions would be appreciated.
   / Hey! Greg here Ford 1320 4wd #2
Welcome to the forum.
How many volts are in the battery.
Are the grounds clean.
   / Hey! Greg here Ford 1320 4wd #4
Welcome to TractorByNet. :tractor:
   / Hey! Greg here Ford 1320 4wd #5
Welcome to TractorByNet!
I moved your thread to the Ford/New Holland Owning & Operating forum. :)
   / Hey! Greg here Ford 1320 4wd #6
Sounds like a short to the starter or a bad ground to the frame... Check your connections to the solenoid and starter also for any damaged wiring possibly caused by the crossed terminals. Once the magic smoke gets out of those wires it's hard to get it back in. ;o)
   / Hey! Greg here Ford 1320 4wd #7
Make sure the gear is in Neutral and tractor wheel chocked. Directly jump the starter by passing interlocks and potential bad connections to see if starter turns.
JC,
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
KUBOTA KX080-4 S2 EXCAVATOR (A51246)
KUBOTA KX080-4 S2...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51246)
2018 GENIE GTH636...
2021 Bradco MM60 Mulching Head (A51573)
2021 Bradco MM60...
