Hew Holland Hayliner 273 bale lengths
   / Hew Holland Hayliner 273 bale lengths #1
Kaptain Kill
John Deere 5520
My 273 baler works great with one exception. Lately it occasionally makes a really short bale, and goes right back to making longer ones. Are there supposed to be "teeth" on the Trip Arm? It looks pretty smooth where it rides against the toothed disc. I am thinking I may need to replace the Trip Arm (part# 706568) and the the disc it rides against (part# 41521). Has anyone had this problem? Thanks!
Kaptain Kill
   / Hew Holland Hayliner 273 bale lengths #3
Yup, replace them or drive very slow where bumps won’t dislodge the arm kicking out a short bale.
   / Hew Holland Hayliner 273 bale lengths #4
...and be happy it's tying properly. Nothing more exasperating than a knotter that won't tie properly.
I might add that with a NH bailer, adding some weight to the trip arm (I machined a piece of steel bar that slipped over the trip arm and secured to the arm with 2 clamp screws), eliminated most of the odd sized bales. The NH trip arm is light weight and prone to jumping on rough ground if the bailer is bouncing around any, especially when the knurled feed sheave gets worn a bit.
The parts aren't all that expensive to replace and in reality, you only need to replace the knurled sheave, not the trip arm itself. The trip arm is spring loaded so the contact point between the arm and the knurled sheave is pretty constant, new on worn.
The other thing to consider is keeping an audible count of your bale slices as the machine makes a bale. You want a consistent slice all the time. I like to run 8-10 slices and I pay no attention to pto speed at all. Everything I do is by ear, not input speed. That may or may not work for you. All depends on your pto input horsepower. In my case, I'm never running at rated pto speed, always less, but then I have an abundance of pto horsepower anyway.
I bought the disc a couple years ago, but not a trip arm. Yeserady I ordered a trip arm as well, but I another question. What is the "spacer" that mounts on the trip arm and is it really needed? The spacer is about 1/2" by 1/2" and Messicks sells it for over $56 each!!!
   / Hew Holland Hayliner 273 bale lengths #6
Not sure which spacer you are referring to but the trip arm sort of controls bale length. My sold 575 was good at making different sized bales.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2019 TAKEUCHI TB290 EXCAVATOR (A51246)
2019 TAKEUCHI...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2014 716PT Homesteader 7'x16' Box Trailer (A52384)
2014 716PT...
2009 John Deere 1810E Scraper Pan (A53342)
2009 John Deere...
