Here's why you grease your loader faithfully.
   / Here's why you grease your loader faithfully. #41
I have an old Model A ear tool for stubborn grease fittings.
It is similar to the chisel that you load with a teaspoon of grease, push is up against the fitting and smack the other end with the brass hammer... hasn't failed me yet.
No idea the psi a hammer smack would generate.
My manual grease gun is pistol grip and has two settings... volume on one and pressure when switched.
   / Here's why you grease your loader faithfully. #42
While reading another thread on this site I ran across this grease gun:
Amazon.com: G. Gun Grease Gun - The frustration-free Grease Gun - Quick and Easy greasing - 6.5ft flex hose standard - LockNLube Lock-on, Clip-off grease coupler fitted standard - Mess-free, Waste Free - Durable Industrial Strength Construction - Heavy-duty, 1�,��� psi Foot Operated Grease Gun - INCLUDES Shipping!: Automotive
Going to go back to my normal analysis paralysis mode now:eek:
OK, perhaps this (another discovery from a TBN thread) is really all I need (main problem is in holding the hose securely on zerks- if I go back to using my manual gun then this would probably be sufficient):
LockNLube | Grease Gun Coupler Tips. Free US Shipping.
   / Here's why you grease your loader faithfully. #43
That G gun looks cool but it is heavy and seems it would be a hassle moving it around. With a Lock n Lube I move around quickly greasing my machines. I think repositioning the G gun would slow me down.
   / Here's why you grease your loader faithfully. #44
bdog, from what I've read I believe that the advantages with the G.Gun are that you can hold a lot of grease (not sure anyone like changing cartridges and dealing with priming the guns) and that it doesn't require you to use weak/injured hands (that's the primary factor that someone had for getting one).
I wish that I'd heard about the LockNLube a long time ago. Not sure if this would solve my issue of trying to get the coupler on the horribly located fittings on my Kubota.
   / Here's why you grease your loader faithfully. #48
I think I'll give my wife a grease gun for her birthday, too.
And maybe she will buy a vacuum cleaner for you................ that has zerk fittings.:D
   / Here's why you grease your loader faithfully. #49
That vacuum better have some grease in it suitable for high speed. Those turbin fans in Vacuum's really spin fast. :laughing:
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2020 John Deere 1025R MFWD Compact Tractor (A56435)
2020 John Deere...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2017 Make...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
(3) CASES OF NEW PLATES (A58374)
(3) CASES OF NEW...
DIGGER DERRICK (A55973)
DIGGER DERRICK...
